Flat Top 4.8 Pistons into my 5.3 HOW TO Video Here
#83
I like to run premium in my vehicles any way. Last time i calcualted it, it was about $2-$3 more a tank to fill with premium. To me it was work it. I get more power, a lil more MPG and a better smelling exhauast.
But! I do plan to test the limits and see how it runs with regular in it once its in the truck.
#84
Got the 5.3 with 4.8 flat top pistons, TSP 220r cam and ported heads running on the engine stand last night. Sounds good! Check it out!
http://youtu.be/VogkaVNGkCU
#86
Custm2500's Rude Friend
Oh damn! Looks like trouble waiting to happen!!!
FWIW I run my LQ9 on 87. I could get more aggressive with the timing and tuning with the 91 Octane we have in CA But It's so minimal to me that I decided to leave it alone. I'd rather save my 20-30 cents a gallon difference here.
#87
Glad I ran it before install too. I noticed that my front seal is leaking pretty bad. I also got the chance to do a compression test last night. I've attached a pic of the results. I dont know what to say about number 6.
Is your LQ9 on a factory tune? and what is at 10:1?
#88
lol yea, it does look like trouble. I seem to like to take chances or some may say that I like to learn the hard way. Its me thinking outside the box though. The stand seems to be pretty sturdy though. I've run three engines this way so far. When I did the first one I was intending on building it into a collapsable full running stand with radiator and all. The furthest I got on that is putting wooden blocks under the front of the pan for support. lol Guess I really need to make a support for the front at least.
Describe the Wet method you used please.
They dry numbers look good. Run it!!!
#89
Well, its been a long time since i've done a wet compression test. I didnt have an oil gun, so I used WD40 :smb: . I sprayed it into the cylinder for 4 seconds, hooked up the tester and turned it over 5 rotations. Less then 4 seconds didnt change the compression. I retested a few of the cylinders a couple times to get the the seconds I sprayed into the cylinder.
#90
I got a quick update video up on the '87 Chevy truck after the 5.3 swap from last weekend. Check out the link below. Its got a shaved truck intake, flat top 4.8 pistons, 220r cam, home ported heads with 2" LS1 valves and a 4l80e trans. More and better videos to come. Enjoy!
5.3 Swap Update! Its in and driving! '87 Chevy Truck - C10 R10 LS1 - YouTube
