Flame me if you must, but a engine swap question
Old Feb 5, 2012 | 05:50 PM
  #21
cttandy's Avatar
Originally Posted by TIM Z
Just replace the lifters, the DOD ( Displacement on demand) engines use 8 standard and 8 DOD lifters, DOD Lifters are junk. Just replace them with LS7 lifters and go about your plans
Since I am using the 01 harness, what about the 58x to 24x reluctor wheels stuff and all that jazz.
Old Feb 5, 2012 | 05:56 PM
  #22
cttandy's Avatar
I don't have the motor yet, would it better for me to go back to looking for the LQ4?
Old Feb 5, 2012 | 06:12 PM
  #23
TIM Z's Avatar
11 sec. Truck Mod
Well since your going for a daily driver /tow performance build i would get the 6.0, it already has an advantage of TQ you need for your heavy vehicle.
But for an all out performance build the alum 5.3 would be baddass! But like said youve got a big vehicle and more cubes will be friendlier to it.
Lingenfelter i believe has the reluctor conversion box to do what you need if you go that route.
Old Feb 5, 2012 | 06:14 PM
  #24
cttandy's Avatar
LQ4 search continues...........
Old Feb 5, 2012 | 06:21 PM
  #25
TIM Z's Avatar
11 sec. Truck Mod
Good choice,
Please document your build!
My Dad has a georgous rust free black 99' suburban, the trans is on the way out and im going to swap in a 6.0/80E/t case in it for him.
Old Feb 5, 2012 | 06:24 PM
  #26
cttandy's Avatar
Good choice,
Click on the build thread link in my sig. My burb is 94, so the swap will be a bit different.
My wife has a pretty nice 99 suburban that might get a 5.3L if this works out like planned.
Old Feb 6, 2012 | 09:17 AM
  #27
zero2sixT's Avatar
Originally Posted by cttandy
could you share you logic?
The 80e has a tall first gear. Typically, less horsepower get to the ground through an 80e also. With a 5.3 in front of it, your heavy burban won't have much of a low end pull.
The L33 is a good engine. $600 is a good deal for one. The lighter block really isn't going to be that big of a gain for you. The 799s and the 87mm intake can easily be swapped to the 6.0, while its on an engine stand. Price of used 799s are falling a lot. I've seen them go for $250, sometimes less. I see 87mm/90mm complete intakes go for a few hundred also.
Even with the 317s and 78mm intake, the 6.0 still puts down more low end.
Not 100%, but im not sure you can run a DoD cam with non-DoD lifters. Can't remember when I helped a friend do a cam/verter swap on a DoD equipped truck. I know you want to go with a non-DoD valley tray and oil pump.
Also not sure if a fwd drive engine is plug and play with a rwd transmission.
The 6.0 is just a better option for such a heavy vehicle that tows. $1000 from a trusted source is a fairly good deal.
IMO, go with the 6.0. Or keep the 60e with the 5.3
Thats the dumbest thing ive heard.
maybe you should get out more
Old Feb 6, 2012 | 10:29 AM
  #28
Vortec350ss's Avatar
I agree with zero2sixT here. Its would be overkill with that engine. I feel like it would chew up way too much power off the line. I'll never say the 80e is a waste of time, but without some serious mods a 5.3 just can't stress a tranny the same way a 6.0 can. IF reliability and strength are your main concerns then go with the 80e all day regardless of which engine you end up with.
Old Feb 6, 2012 | 10:45 AM
  #29
cttandy's Avatar
Heavy truck pulling heavy trailers = strength concerns.
Unless the guy wants to do a straight trade out for my labor, I am just going to run my 5.3L and 4L60E I have now.
Old Feb 6, 2012 | 11:42 AM
  #30
cttandy's Avatar
Definitely a no go on the trade, Tired of the waiting game. Moving forward with a cammed 5.3L and the 4l60e.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
creekrat
Aug 2, 2015 01:27 AM
Mark_k
Jul 9, 2015 12:37 AM
