Finally went to the track...
Old May 25, 2007 | 04:05 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
05-04-2004, 09:26 PM wow, that is old!!
Old May 25, 2007 | 04:10 PM
silent1's Avatar
Just looked at your site, you're running 3.73's. So that might be it, I'm running 4.10's.
Old May 25, 2007 | 04:55 PM
trever1t's Avatar
that's only a 10% difference in gear ratio. I run 30.5" tires too. What was your approximate HP at that time? I'm making decent torque (564) at very low rpm and haven't yet had any traction issues while in 4wd on dry road. Wet, no problem. Damp, no problem, but dry, no way.
What is your current setup? Are you RC?
Old May 25, 2007 | 05:24 PM
silent1's Avatar
I'm running a 29" tire. I'm an ext. cab 4x4 as well. At that time I had about 450RWTQ at 3400~RPMs. Current set up is MID LS1 block 427.
Old May 25, 2007 | 06:38 PM
trever1t's Avatar
[jealous] damn that must be nice....
smaller tire and lower gears may it. TC stall speed?
Old May 25, 2007 | 09:11 PM
silent1's Avatar
Thanks. Right now I'm running a Vig 3200.
Old May 26, 2007 | 09:16 AM
hEY sILENT,....give us some specs on your truck. I'm eager to see what set-up you're running.
Old May 26, 2007 | 06:04 PM
silent1's Avatar
MID LS1 block 4.125" bore
Callies 4" crank
Diamond -7cc pistons
Oliver Rods
AFR 225's w/ Comp 921's
Jessel adj. rockers
Morel lifters
Tony Mamo ported Fast 90
LG G5XX cam
Dynatech Headers w/ custom 3" collectors
3" true duals w/ X-pipe
FLT/FLP level 5 4L65E
4.10 w/ Eaton posi and rear end girdle
42# injectors w/ in-tank walbro 255
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
