few questions???
Old Jul 18, 2006 | 12:05 AM
regency's Avatar
Default few questions???
i have the rear o2s turned off or deleted for no cats, and was wondering if when i got LTs and a ORY since i just have the cats cut out of the factory pipe, if i could just unplug the sensors or would i have to weld in some bungs???
i just changed my gears over the weekend from 3.73 to 4.11 and was wondering how much of a difference it would make just having my computer tuned for them. just swapping the gears i had a noticable difference, and a few times i have actually laid out some rubber when it caught 2nd!!!!
what kind of difference would a 160 stat make over stock, since my truck sits around 200 - 210. also i have read that when replacing a thermostat that it actually reduces the tranny temps as well, is that true???
Old Jul 18, 2006 | 12:53 AM
all the thermo does is open the flow of your coolant at a lower temp so it really doesnt make that much of a difference aside from not heatin up as fast. you will see no drop to temps in the end of the day. i havent heard anyone tune for gears other than the speedo recalibration. if you already have your rear o2's deleted, they arent registering anything with the computer so with some LT's i would think you just zip tie them up somewhere and leave them disconnected or something
Old Jul 18, 2006 | 07:52 AM
98TAauto's Avatar
if they are turned off already then yes you can just screw them out and tape up the ends somewhere. Id leave them in and just cut the cats out though since sometime you might wanna run them again.
getting edited for the gears would get your speedo back in check though
as far as the thermo.. it would help the motor stay cooler but a 160 stat is overkill in the summer since the fans and etc would run 24/7 trying to stay cool. I run my stocker still for that reason
Old Jul 18, 2006 | 11:38 AM
regency's Avatar
so basically the thermostat is a mod thats not worth the time and or money!!!! and i know that i can unscrew the o2s from the y-pipe, but i was wondering if i could just unplug them and keep em in my shop in case i need them. just not under the truck still??!!
Old Jul 19, 2006 | 12:28 AM
im sure you can. the thermo is a fine mod. cheap too and easy. just get a 180* for 27$ and be done with it
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
