few more questions
Old Feb 27, 2003 | 12:19 AM
Banned
Default few more questions
ok, i'll start with the valvetrain. i plan on using comp 918 springs, and i already have a set of 7.4" hardened pushrods. what other changes will be needed or beneficial. like lifters, roller rockers etc?.?.? second, is there any benefit to the double timing chain? i'm gonna go with diamond flat top pistons from SMC performance with retainers rings and pins, probably stock rods with arp bolts,would there be any need for head studs or are good stock bolts fine? and finally stage 2 6.0 heads from TEA--->
i figured on some SVO 30# injectors, maybe bigger if you have any input to warrant a bigger injector. and probably an inline fuel pump.
i'll probably stay with a truck intake manifold since there isn't much difference between it and the car one as far as flow from what i've heard. Are there any other airflow changes i will need to make with the big motor? (i.e....maf, tb, etc?)
anything else i'm leaving out here? tranny/rearend, but i'll deal with that when i need to. will there be any computer problems with the 6.0 swap? i plan to get EDIT but if i don't right off the bat will there be any big problems?
thanks guys, i have the ball rolling...just locating all the parts i can afford for the time being and laying out a plan for the build. hope it ends up being as much fun doing it as it is planning it out.
<img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Feb 27, 2003 | 01:28 AM
sleepersilverado's Avatar
Default Re: few more questions
how about some 918 titanium retainers <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> 150 Shiped
Old Feb 27, 2003 | 07:37 PM
Banned
TTT
Old Mar 3, 2003 | 01:52 AM
blacknight02's Avatar
Hey man you still have that cam? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
