Fast lsxrt drivability problems
Old Sep 10, 2012 | 03:45 PM
  #81
black00chev's Avatar
Slowest turbo build ever!
Sounds like its time for either an Edelbrock Pro-Flow or Holley Hi-Ram!!!
In any case, it sucks to hear you're having such problems with the FAST unit being as expensive they are.
Old Sep 10, 2012 | 05:10 PM
  #82
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
nah im going to probably do a TBSS/NNBS 90MM setup you loose a ton of low end grunt with the Edelbrock pro-flow dosent start to make power until 3500 to 4000 grand i dont really know to much about the Holley most likely same results since they look identical.
Old Sep 14, 2012 | 09:32 PM
  #83
N/ALS1's Avatar
Did you have trouble lining up the 10 mounting holes? Mine where a little off.
Old Sep 16, 2012 | 01:21 PM
  #84
only one of them gave me a problem but it was doing it even with my stock truck intake
Old Sep 19, 2012 | 08:15 AM
  #85
Well I put a evap smoke machine on the truck last night and my NW92 TB is leaking at the throttle shaft
Also the intake is not leaking around we're the two halves meet or anywhere else so I can rule that out.
Old Sep 19, 2012 | 12:51 PM
  #86
N/ALS1's Avatar
Good to hear that. So what's your next plan.
Old Sep 26, 2012 | 01:00 PM
  #87
tcr0148's Avatar
I feel your pain bro. I was almost at the same point as you back in April. After weeks on trouble shooting, logging, swapping gaskets, injector o-rings, redecking the port surface on the intake,........I was at wits end and then I by passed the factory PCV system. Instead of pulling vacuum from the drivers side of the manifold to the drivers side valve cover rear port, I installed two catch cans and pulled vacuum from the valley cover front port and moved the brake booster hose from the rear of the manifold to the drivers side. This cured all the gremilings that I had been so upset about.
Old Sep 26, 2012 | 01:22 PM
  #88
N/ALS1's Avatar
Post some pics, always better with a visual. Lol
Old Sep 26, 2012 | 02:34 PM
  #89
Yes please do that would help out a lot
Old Sep 26, 2012 | 04:20 PM
  #90
oakley6575's Avatar
That is interesting.
