Fast lsxrt drivability problems
#111
Fastest D1 Procharged Truck
all i can say is wish i just did the TBSS setup im much happier and it was cheaper
#112
I had problems. It would flare on start up real bad. It would cruise without hitting the throttle. Also it would stall at red lights and stop signs(sometimes). I had 2 tuners play with it($$$$). I forget the settings in the tune we ended up adjusting. I think "stall saver" and something to do with flair. I'm not a tuner LOL. We were blaming he 102 TB for the erratic behavior.
I did pick up over .15 at the track. Then the motor blew up.
I am installing it on the new motor. I need new gaskets all around. I want to try what TCR0148 suggested. I'd like to see a pic of the install on his cousin's truck.
I can't give up on this intake. It was too much money.
#114
I just figure, I already spent the money and installed it once. I'm going to deal with it and make the best of it.There are some write-ups on the hptuners forum. Most of that stuff is over my head though.
#115
Bro, trust me......you did not make a mistake! I had issues as well when I first installed the intake. I figured out that my leak was coming from the pcv valve to the manifold on the drivers side valve cover. I by passed pulling vacuum from the mainfold (plugged them off) and ran two catch cans and pulled vacuum from the orfice on the front of the valley cover.
#116
I have a LSXrt on my 402. It has been a bear with idle but it has been running as a weekend driver for 1 year with this setup.
Old intake as my OBS with 78mm maf and it made 434rwhp. When i went to LSXrt and 92 FAST TB it made 507rwhp. We deleted the MAF and converted to Speed Density tuning.
Idle is annoying but liveable.
#117
#118
i have the lsxrt 102 on my 2012 5.3 rcsb install was a pain and idles alot worse than the stock intake. i had area47 retune it and got circled 3200 stall put in and it definately runs bette now but it has a crazy intermittent idle mostly when motor is cold. im getting 4.10 gears and a comp dod/vvt cam in the spring hopefully the intake will respond with the mods! anybody need my stock intake with only 3000 miles on it?
#119
When mine was on the 5.7 with the 232/234 i had a lot of flare on start problems, got that worked out by changing the crank flare table. After that had no problems, I did notice that on the 5.7 and the 390 it does idle a little higher (900) then the stock intake did, but the gains seem worth it to me. Overall im glad i made the switch.
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
