Fast lsxrt drivability problems
Old Sep 4, 2012 | 01:04 AM
  #51
N/ALS1's Avatar
Hopefully this gets some resolution.
Old Sep 4, 2012 | 08:09 AM
  #52
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
If putting my stock intake back on doesn't solve the problem only thing left is something in the tune isn't right I'll find out tonight.
Old Sep 4, 2012 | 01:02 PM
  #53
bgray's Avatar
TOTM: June 2007
Did you have the CAI installed in those videos? Sounds like its got an awesome vaccum leak,?
I found my LSXRT video
Old Sep 4, 2012 | 02:25 PM
  #54
Yup I had the CAI on its 4-inch setup sounds like a small child could get sucked up when running lol
Old Sep 4, 2012 | 05:20 PM
  #55
N/ALS1's Avatar
@bgray- what did you do to resolve the leak?
@twolow- did already clearance he intke for he head bolt washers?
Old Sep 4, 2012 | 07:00 PM
  #56
bgray's Avatar
TOTM: June 2007
I had 2 of these lsxrt...both leaked badly.
Sent both to comp cams, both bases were badly warped. They fixed them and sent them back. I returned the one and kept the other, still havent installed it as i have no faith in them.
Old Sep 4, 2012 | 07:26 PM
  #57
N/ALS1's Avatar
Damn im in the middle of an install and now im worried. Truck has been torn apart due to my daughter being born and couldnt work on it. I will install it and try to blue rtv seal every gasket possible. The only problem I see with mine is the purge solenoid, but will fix that with jb weld as I dont think it is really that stable and pose a leak.
Old Sep 4, 2012 | 07:58 PM
  #58
N/ALS1's Avatar
Bgray are you on youtube sporting bassanni mufflers?
Old Sep 4, 2012 | 11:00 PM
  #59
well guess what i put the stock intake back on truck runs tittys i also noticed the intake dosent make so much noise either
and yes N/ALS1 i did notch out the intake for the head bolts
im kinda thinking the TB is to big think i might try putting the stock TB on the LSXRT and see what happens.
Old Sep 4, 2012 | 11:07 PM
  #60
N/ALS1's Avatar
Damn I wonder if I should've got the 92mm fb now. But I hope I have some good luck with mine.
