Fans finally done.......
Old Aug 28, 2007 | 04:57 PM
99Silver6.0's Avatar
Default Fans finally done.......
05 fans, 34" radiator, 145amp alternator. Pretty simple install. I spent a good while on the wiring making extremely stock-ish. Hid the relays/harness under the fuse panel. I used a 3 relay setup triggered by 2 PCM outputs. Pin 33 and 42. All fan control via the PCM. Cool pretty well witht he bigger rad.
Old Aug 28, 2007 | 05:13 PM
Sport Side's Avatar
Nice.
Old Aug 28, 2007 | 06:03 PM
03sierraslt's Avatar
I am not familiar with pin 33, what does it control?
Old Aug 28, 2007 | 07:03 PM
Think in 03+ trucks its set by default for auto-recirc. Which isnt even used. When series/parallel fans is selected in EFILive or whatever it will run dual speed fan setups without hacking into the clutch wire.
Old Aug 28, 2007 | 08:30 PM
budhayes3's Avatar
PT's Slowest Truck
Very nice...looks totally stock and I like the 2 pin PCM set up
Old Aug 28, 2007 | 08:33 PM
BlackGMC's Avatar
Resident Retard
Very, very nice!!!! Looks like it came that way!!!
Old Aug 28, 2007 | 11:02 PM
Bumpers's Avatar
Nice man, Looks good! I will be doing sumthin similar very soon!
Old Aug 28, 2007 | 11:14 PM
LEballistic's Avatar
can you post a wiring diagram you used
dsbodley
Nov 14, 2015 09:46 PM
CD82
Oct 23, 2015 07:32 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
Wrecker 426
Sep 30, 2015 09:39 PM
