Fans Fans Fans
Old Oct 21, 2006 | 01:15 PM
04BlackGmc's Avatar
10 Second Club
Default Fans Fans Fans
so choices seem to be aftermarket
New truck fans
or ls1
what are other choices...
someone brought up impala fans, but cant find any measurements.Which is the same as a monte carlo.
Old Oct 21, 2006 | 01:18 PM
04BlackGmc's Avatar
10 Second Club
http://www.carpartswholesale.com/sto...LA&sku=C160910
Old Oct 21, 2006 | 02:56 PM
jakebdb56's Avatar
get the new truck ones. those impala fans look wayyy different than the ones on my truck.
Old Oct 21, 2006 | 10:14 PM
04BlackGmc's Avatar
10 Second Club
then i need a 34" Radatior
Old Oct 21, 2006 | 10:58 PM
Derek @ EDO's Avatar
FormerVendor
just go LS1
Old Oct 21, 2006 | 11:04 PM
BlackLM7's Avatar
F-body LS1 fans ('98-'02) are the only stock units that will bolt on directly to your truck. I also think LT1 fans ('93-'97) will work too. Your truck should have a 28" radiator. After the warranty expires on my truck, I plan on installing LS1 fans with a Nelson harness.
Old Oct 22, 2006 | 08:23 AM
COLDZ71's Avatar
It kind of depends on how much you want to spend. I just put a set of ls1 fans and a white1 harness on my truck. I bought both the fans and the harness off of the classifieds on this site. Total cost including installing them was about $175. They work great, I have no complaints. I didnt go with aftermarket fans or 05 efans just because I wasnt about to spend $500+ on some electic fans.
Old Oct 22, 2006 | 08:35 AM
Rhino79's Avatar
9 Second Club
LS1 fans all the way, Flexalite=
Old Oct 22, 2006 | 09:26 PM
04BlackGmc's Avatar
10 Second Club
ls1's it is then
Old Oct 22, 2006 | 10:01 PM
negativeswitches's Avatar
i'm not on the flexalite boat
i have ls1 fans - they work good
i also have a fan of an older ford tarus 3.0 it's 2 speed and DAMN does that sucker move some air
i dunno about the dimensions but it would be sweet if you could fit 2 of those on something, you'd definately never have an overheating problem
my buddy is running a lincon towncar fan dont know what year make and model but it's one LARGE single fan 2 speed uses the same motor as the 3.0 tarus jsut alot larger shroud and fan blade
something to look into
-erik
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
