Fan clutch removal?
Old Jan 31, 2003 | 03:27 PM
1TRUESS's Avatar
Default Fan clutch removal?
How do I do this? It has a single bolt, fan and pully turns with wrench and slips with me holding it. Is there a trick?
Old Jan 31, 2003 | 03:38 PM
graygmc's Avatar
Default Re: Fan clutch removal?
do a quick search. there has been a lot of different ways to remove it, posted on here.
Old Jan 31, 2003 | 03:47 PM
Ryan23silverado's Avatar
Get a rubber strap wrench from Sears (the longest one you can find). I think mine is like a foot and a half... Put that around the fan pulley after cleaning all of the dust off with windex or something. Then try to set the handle of the strap wrench on another part of the engine so you don't have to worry about holding it in place. Next get a BIG wrench, I used a monkey wrench, and a cheater bar (pvc pipe etc. I used the end bar on my jack) and slide it over the handle of the wrench. This should give you clearence of engine stuff and enough leverage to break the fan loose.
Good Luck, Ryan
Old Jan 31, 2003 | 05:11 PM
I used a big open end wrench, it's like a 1 5/16" and a hammer. Give the wrench a couple of QUICK hard wraps with the hammer, mine came right off that way.
Jim
Old Jan 31, 2003 | 05:27 PM
1TRUESS's Avatar
Y2K, Thanks but I tried that already. Ryan23silverado, great info it worked. Thanks again!
Old Jan 31, 2003 | 07:50 PM
parish8's Avatar
single digit dreamer
i used the hammer trick also, worked like a charm. it will turn and you will have to get a new grip on it a few times, like maybe an entire revolution.
Old Jan 31, 2003 | 09:34 PM
JWRENCH's Avatar
If I remember right it's left handed threads too. The hammer and wrench way worked for me. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Jan 31, 2003 | 11:17 PM
CashDudeHomie's Avatar
I am not sure what left handed threads are, but mine was on just like any nut would be. The old vortecs had the ones that go on reverse.
Old Feb 1, 2003 | 11:23 AM
1TRUESS's Avatar
Used the strap wrench. Worked great! Loosened the same direction as the fan counter clockwise. Thanks again. Was putting on ASP underdrive pulleys. I could really feal a difference. Volts drop but I'm not bothered by it.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Tigger Welder
Oct 1, 2015 08:41 AM
69z-28
Sep 21, 2015 07:31 AM
Shotguntommy
Sep 15, 2015 05:24 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
