False Knock?
Here's a screenshot. I can make it bigger if you can't see it.
http://www.woracing.com/truck/screen...false%20kr.jpg
False knock I don't know?
8.5 psi. 29* up top.
I have swapped to the 6.0 heads too, so the CR is around 8.5.
The 15psi you see on the log is actually the OEM map sensor picking up 105kpa.
Yeah I don't know to much about tuning yet. I hope to get hptuners soon. Is this about the same set up you had when you pulled off the 12.6 run?
lator
Yellow
lator
Yellow
lator
Yellow
With sticky tires ... this would be on it's way to a solid 12 second run.
i get false knock whenever i downshift and get into it. 4 degrees. from 4800 to 6400. it doesnt matter what i do to the timing. i have put it to 18* and it is still there. if i get on it from a dead stop it is not there. i have tried all kinds of things with no luck. it doesnt pull timing and it is not audible.
