False Knock?
Old Feb 21, 2005 | 10:53 PM
Flyer's Avatar
Default False Knock?
Here's a screenshot. I can make it bigger if you can't see it.
http://www.woracing.com/truck/screen...false%20kr.jpg
Old Feb 21, 2005 | 10:57 PM
Yellowsierra's Avatar
15 psi and 22 deg. of timing. False knock I don't know?
Old Feb 21, 2005 | 11:02 PM
moregrip's Avatar
what a rush!
not very clear bro
Old Feb 21, 2005 | 11:03 PM
Flyer's Avatar
8.5 psi. 29* up top.
I have swapped to the 6.0 heads too, so the CR is around 8.5.
The 15psi you see on the log is actually the OEM map sensor picking up 105kpa.
Old Feb 21, 2005 | 11:07 PM
Yeah I don't know to much about tuning yet. I hope to get hptuners soon. Is this about the same set up you had when you pulled off the 12.6 run?
lator
Yellow
Old Feb 21, 2005 | 11:09 PM
Flyer's Avatar
Originally Posted by moregrip
not very clear bro
Blown up Better?
Old Feb 21, 2005 | 11:10 PM
Flyer's Avatar
lator
Yellow
Yup ... except it was shifting whre it was suppose to (6600) instead of tagging the rev limiter at 6900 rpm.
With sticky tires ... this would be on it's way to a solid 12 second run.
Old Feb 21, 2005 | 11:11 PM
Flyer's Avatar
I take that back ... It's about 6* more timing up top from what's in the video link in my sig, if that's what you were referring to.
Old Feb 22, 2005 | 02:07 AM
BigTex's Avatar
Is that KR happening during the shift? Looks like it. Its interesting that it goes away so quickly.
Old Feb 22, 2005 | 05:47 AM
one03sierra's Avatar
Formerly one92rs
Talking
i get false knock whenever i downshift and get into it. 4 degrees. from 4800 to 6400. it doesnt matter what i do to the timing. i have put it to 18* and it is still there. if i get on it from a dead stop it is not there. i have tried all kinds of things with no luck. it doesnt pull timing and it is not audible.
