factory trans cooler & yank 3000
Old Jan 6, 2003 | 06:15 PM
IslandTahoe's Avatar
Default factory trans cooler & yank 3000
Would the stock trans oil cooler offer enough cooling for Yank 3000 Torque Converter. The current trans temps are below 200 but do get close at times. I don't have any idea how much more heat the TC generates.
Adding an additional cooler into the loop would probably be good insurance unless someone knows its not necessary.
Old Jan 6, 2003 | 06:29 PM
parish8's Avatar
single digit dreamer
Default Re: factory trans cooler & yank 3000
seems like yank says you dont need it for that stall but i would get one, they are only $40 or so and a tranny is $2000. i wasn't monitoring my temps but when i was towing in the mountains with my truck there were long periods of time the converter wasn't locked, it had to be geting hot. i figured out it was smoother and less work for the truck to drop it into 3rd and since it could hold it's speed the converter never unlocked.
Old Jan 6, 2003 | 06:59 PM
Patrick G's Avatar
LS1 Tech Administrator
With the big 278mm Truck Thruster 3000, I have not needed a tranny cooler according to Autotap. Apparently, the Tahoe radiators are pretty efficient.
Old Jan 6, 2003 | 07:28 PM
Thanks guys,
I figured the stock cooler would/should handle and I will put another aux one in the loop eventually, but I may just install the TC first and have some fun now.
I'll worry about the extra cooler install and plumbing after. If the temp skyrockets, we are talking about Hawaii, it will be sooner than later.
Old Jan 6, 2003 | 08:51 PM
wolfman jack's Avatar
did your truck come with a facory external cooler as well as the one in the radiator?
Old Jan 7, 2003 | 11:21 AM
Yes, I have the factory cooler mounted in front of the radiator.
Old Jan 7, 2003 | 04:15 PM
red53gmc's Avatar
My temps with my factory aux cooler and yank 3200 in my 01 were always in the 160* range, never close to 200*. In my 02, before I put the B&M cooler the temps were always close to 200* with the factory converter. Now they are at about 170* with the yank 3200.
1slwgto
Aug 16, 2015 06:40 PM
OLD BULL
Aug 1, 2015 05:00 PM
Ls3silverado
Jul 31, 2015 04:22 PM
ferrellrooster
Jul 17, 2015 07:07 AM
bsn1989
Jul 16, 2015 08:20 AM
