f body crank different than truck?
Old Sep 7, 2003 | 08:53 PM
highgmc's Avatar
Default f body crank different than truck?
can you install a LS1 from an f body into a 5.3 4wd truck?
I thought I read somewhere that the end of the crank(trans side) is different or something?
Old Sep 7, 2003 | 09:02 PM
CHAGO's Avatar
Default Re: f body crank different than truck?
you should be able to use the 5.7 LS1 crank since the blocks are pretty much the same. I was going to put a 5.7 crank on the 6.0 I had.
Old Sep 7, 2003 | 09:06 PM
highgmc's Avatar
i remember a post where I guy ran into problems of some sort
Old Sep 7, 2003 | 09:21 PM
CashDudeHomie's Avatar
I think you are talking about the 99-00 iron 6.0s because the crank wouldn't work with the 4L60E, but lucky for you the 5.7 doesn't have this problem.
Old Sep 7, 2003 | 09:25 PM
BigTex's Avatar
That was with a pre 2001 6 liter. Its crank was longer, so it would work with the 4L80 transmission. That model comes with iron heads.
A standard LS1, LS6, 4.8, 5.3, and newer 6.0 engine can be swapped with no physical differences (except weight and 1 non-critical accessory bolt hole).
Old Sep 7, 2003 | 09:32 PM
highgmc's Avatar
hmmmmmmmm
Old Sep 7, 2003 | 10:10 PM
XLR8NSS's Avatar
Adkoonerstrator
hmmmmmmmm
I see a MTI 422 in your sig. that will fit right in your truck.
Old Sep 8, 2003 | 07:54 AM
GREGGO's Avatar
The 5.7 crank is also lighter than the 5.3 and 6.0 crank. It's drilled out on the end wher the connecting rods bolt up.
Old Sep 8, 2003 | 10:11 AM
gonzo 6.2's Avatar
I started with a 2000 6.0 that came out of a wreck with little to no miles on it.I swapped in a 5.7 crank and it works fine,if i had it to do again i would have spent the extra and had the bottom end balanced as the 5.7 has a slightly different balance than the 6.0s.Valvegod said this and he claims he has interchanged cranks with no problems.
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
