f body crank different than truck?
you should be able to use the 5.7 LS1 crank since the blocks are pretty much the same. I was going to put a 5.7 crank on the 6.0 I had.
That was with a pre 2001 6 liter. Its crank was longer, so it would work with the 4L80 transmission. That model comes with iron heads.
A standard LS1, LS6, 4.8, 5.3, and newer 6.0 engine can be swapped with no physical differences (except weight and 1 non-critical accessory bolt hole).
I started with a 2000 6.0 that came out of a wreck with little to no miles on it.I swapped in a 5.7 crank and it works fine,if i had it to do again i would have spent the extra and had the bottom end balanced as the 5.7 has a slightly different balance than the 6.0s.Valvegod said this and he claims he has interchanged cranks with no problems.
InsaneDomestics
Jul 27, 2015 02:42 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
