exhaust resonating
Old Nov 28, 2008 | 08:30 PM
BIRCHZ71's Avatar
Default exhaust resonating
ugh! the 1800 to 2400rpm......sounds like crap in my truck. I have the stock manifolds going a single 2 1/2 pipe to a 40 series Flowmaster. 1 in 2out. I used to have it all the way to the bumper turned down where u couldn't see it. I wanted a little deeper sound so i sawed both pipes about a foot after the muffler. sounds good at idle but the drone/resonating is there like i have a cutout. If i weld some turn-downs or side exit tips on will it help?
Old Nov 28, 2008 | 08:32 PM
ChevyTruck's Avatar
something else
Side exits will help a little.
Old Nov 28, 2008 | 08:37 PM
viciousknid's Avatar
Where's the Beef?
And another muffler or Resonator
Old Nov 28, 2008 | 11:16 PM
95 bright teal's Avatar
Flowmasters are known to resonate in our trucks.
Old Nov 29, 2008 | 12:48 AM
2001CamaroGuy's Avatar
BLOWmasters resonate....period...
Old Nov 29, 2008 | 09:42 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Magnaflow.... Pure SWEETNESS!!! Quiet idle inside cab. Lopey, musclecar sound exterior (idle)... WOT, will get you admirable eyes! No resonance with the 24" muffler...
Old Nov 29, 2008 | 09:53 AM
GMCtrk's Avatar
I have the magnaflow 22", it resonates bad in the cab around 1700rpm
Old Nov 29, 2008 | 10:48 AM
006rcsb's Avatar
agreed, I have a rcsb stock manifolds and 2 1/2 pipe to the y and then its 3 inch back. I had a flowmaster single chamber on it with just a turndown after it, it souded great but the drone was too much, so i swapped it for a 24 inch magnaflow and kept the turndown. Now it really quiet at idle and cruising and when you stand on it it has a nice deep growl that sounds much better, not only that but absolutely no drone at any rpm. Now when I get on it Im not as worried about being such a cop catcher.
Old Nov 29, 2008 | 11:07 AM
KLUG'S SS's Avatar
FormerVendor
Can't go wrong with a Magnaflow IMO. I have ridden in quite a few cars and trucks with Magnaflow mufflers and none of them had a drone to them at any rpm.
Old Nov 29, 2008 | 11:29 AM
SS94S10's Avatar
Full body Magnaflows, I find don't drone, the flowmaster's are known to. I put a resonator in a flowmaster system once and it seemed to help. Didn't wuite it down much but took the highway 1900Rpm drone out. Resonates are cheap too, like $150 installed, doesn't need to be fancy.
