engine wont come out!
Old Aug 12, 2007 | 04:52 PM
Toaders's Avatar
Default engine wont come out!
Guys I have every bolt off this thing but it wont seperate from the bellhousing what can I do?
Old Aug 12, 2007 | 05:02 PM
Quik's Avatar
5 year bitches!
its seized together. you need to smack it with a rubber mallet along the edges. you will alos need a good pry bar to help aid in this. but you should of pulled the entire motor/trans/harness together. it would of been faster and easier....this is from experience
Old Aug 12, 2007 | 05:08 PM
Toaders's Avatar
even though its 4wd? This sucks I have evreything hooked up and it wont budge.
Old Aug 12, 2007 | 05:09 PM
99Silver6.0's Avatar
Those goddam dowels. They can be a bitch.
Old Aug 12, 2007 | 05:17 PM
Toaders's Avatar
been together for 128,XXX I guess they dont want to part
Old Aug 12, 2007 | 08:00 PM
Flyer's Avatar
Make sure you have all the bolts out. If you miss one and it seperates, you will be looking for a new ballhousing. That's experience as well.
I wouldn't use a pry bar unless you had to. Put the jack under the tail of the trans and raise it up. The let it drop and hang on the motor mounts. Doing that a couple of times should work it loose.
Double check all the bolts just in case. Make sure you get the one at the very top. It's easy to miss.
Old Aug 13, 2007 | 01:33 AM
CashDudeHomie's Avatar
Yeah make sure the trans is supported. I just kinda hammered a screwdriver in between to break them loose. The dowels are 3 and 9 o clock. Obviously this isn't the greatest idea because I could crack the housing, but it's worked several times now.
Old Aug 13, 2007 | 03:23 AM
GMC_DUDE's Avatar
I had the same problem. Turns out the engine holds up the front of the transmission, and they will lock together. Putting a jack under the tranny and lifting it a hair made everything pop apart. No hammering necessary.
Old Aug 13, 2007 | 10:34 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
There is a bolt that hides at the 12 o'clock position of the bell -- impossible to see and harder to reach. Popping off the intake manifold and going at it from the top makes it easier.
Old Aug 13, 2007 | 10:53 AM
ZR1 DREAMING's Avatar
How many bolts did you remove total from the trans/bellhousing?
Did you get all 3 from the TC and flywheel?
+1 on supporting the trans also.
