Engine woes or fueling issues?
Old Sep 8, 2022 | 10:00 PM
  #71
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by shakenfake
IAC sensor. Looks a little dirty and gummed up to me. Throttle body cleaner and wipe out the port for it?
yes sir. becareful not to mess with it too much.
Also clean your port hole... unless your dirty like Dan...
When you start it, you will have to bring the RPM up and slowly back it down manually to an idle again. Just let it idle for 10min and it will adjust and set it self.
Old Sep 9, 2022 | 08:51 AM
  #72
dantheman1540's Avatar
Old Sep 10, 2022 | 01:45 PM
  #73
RedXray's Avatar
100% Redneck
Those little MF'ers are $100 new lol
When I rebuilt my LQ9 I didn't have a throttle body. Got lucky and found a new AC Delco TB on e-Bay still in the clamshell with the IAC & throttle position sensor for $76 dollars shipped
Old Sep 29, 2022 | 02:41 PM
  #74
shakenfake's Avatar
Shlumpt
5 Year Member
First time start up will occur after work today. Going to drive it down the street and park it in my new driveway. I don't plan on doing any diag on it just need it to move. Considering smoking it tonight since it is so cool out but I may cut down a tree that is overhanging the parking spot.
@1FastBrick So I will just start it and give it a little throttle, say 1500 RPMs or more? Then back it back down to idle and let it run for 10 minutes correct?
Old Sep 29, 2022 | 02:50 PM
  #75
1FastBrick's Avatar
Basically, yes. It likely won't want to start and run on its own. So you will need to give it a little gas to get it going. Then back it down slowly until you get to your base idle and let it run for 10 minutes. It will self learn and adjust as needed.
As for the Tree Situation, You must only hug the tree. You are not allowed to alter it in any way...
Old Sep 29, 2022 | 02:53 PM
  #76
shakenfake's Avatar
Shlumpt
5 Year Member
The tree got populated by those stupid *** webworms. I want to cut the whole thing down but we'll see. I at least am going to cut all the branches that could fall on my truck.
Roger dodger I'll start with that when I get home.
Old Sep 29, 2022 | 02:56 PM
  #77
1FastBrick's Avatar
Talking
*** Web Worms sounds like a real issue... You should get that looked at...
Old Sep 29, 2022 | 02:57 PM
  #78
shakenfake's Avatar
Shlumpt
5 Year Member
Old Sep 29, 2022 | 08:40 PM
  #79
terravast4's Avatar
you need to cut that whole ******* out if you have *** Webworms. I suggest a sharp pocket knife. Make sure you clean your ******* really good or your pocket knife will get dirty.
Old Sep 29, 2022 | 08:57 PM
  #80
1FastBrick's Avatar
See... I am not the only one concerned here...
