Engine Swap Questions? Please Help
Old Apr 24, 2006 | 09:40 PM
WildRover's Avatar
Default Engine Swap Questions? Please Help
Fellow Backyard/Professinal Truck Mechanics,
I need your help. I posted the following on another forum about a week ago and am not getting any response. Im wondering If I am just an Idiot or what. I have a 96' GMC Z71 with a 5.0L engine and a trans with a major slip, I am looking to rebuild this vehicle with a new motor,headers,CAI,rebuild trans, Rear, & a 2-3" Lift. This will be primarily for Offroad use but I will be driving it on the street fairly regularly. I am asking simply the following:
Does anyone know If I can use the following crate motor in my 96' Sierra Z71?
http://www.crateenginedepot.com/stor...041-P18C2.aspx
I am looking to swap the current 5.0L with a 5.7L I have done a bit of investigation and found I should only need to swap the computer & Knock Sensors. all else should work from the 5.0L. Am I right about this ?
Any input would help!!!!!!!!!!
Old Apr 25, 2006 | 02:52 PM
ktmrider's Avatar
I'm no expert on the GenII motors but seem to remember there being an issue with intake manifolds mating up to the Vortec heads. The other thing I noticed is that motor is listed for "competition or off road use", or non-emission compliant. If you require emission testing in your area you might have a problem passing.
Old Apr 25, 2006 | 08:46 PM
WildRover's Avatar
In this case I would have to do an aftermarket Intake Manifold. Good News they are pretty cheap. WooHoo. Anyone else know if this motor would work & or is a good choice ?
Old Apr 25, 2006 | 08:49 PM
white1's Avatar
Should work fine. If yours is a 96, you already have the Vortec heads, so your intake should work fine.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
creekrat
Aug 2, 2015 01:27 AM
Mark_k
Jul 9, 2015 12:37 AM
