engine swap is done......engine wont stay on?!!!
Old Jul 16, 2010 | 10:04 AM
ssinister04's Avatar
Exclamation engine swap is done......engine wont stay on?!!!
hey guys my engine swap is finally done but the guy who did all my final **** ses it wont stay running....he was thinkn bad ground or the theft lock???
he is checking all ground now....but what els could this be??? i had the pcm tuned by black bear from my truck witha 4.3l to now accept a 6.0l.....
Old Jul 16, 2010 | 10:12 AM
Red03SilSS's Avatar
Does it immediately turn off after he cranks it? If it does then there is a procedure that takes like 30 mins and it will fix that. I forget what it is called, security relearn? or crank relearn. Not sure. I know you start it and it dyes. Leave the key on for about 7-8 minutes until the lock thing on the cluster quits flashing. Turn the key all the way of for 10 seconds then start again and repeat 3 times.
Not sure if thats your problem, but it could be.
Old Jul 16, 2010 | 11:01 AM
someone just told me it may be this...they sed it was the security relearn...but the light doesnt stay on. i also have the crank sensor position code being shown wen he plugged his programmer ....
Old Jul 16, 2010 | 11:19 AM
JennaBear's Avatar
Truck Sponsor
The SEC light doesn't always stay on, you still need to perform the security relearn. Once the security relearn is performed, you can perform the crank relearn with a Tech II or a tool of the like.
Old Jul 16, 2010 | 11:42 AM
ahhh ok ic....by tool of the like what els could we use??? any idea of how long a crank relearn takes what it involves??
Old Jul 16, 2010 | 11:45 AM
JennaBear's Avatar
Truck Sponsor
The crank relearn can be performed with a diagnostics tool like a Tech II. EFILive and HPTuners can perform the relearn as well, your engine guy should know what to do.
The security relearn instructions came in the PCM box.
Old Jul 16, 2010 | 11:59 AM
awsome ill let him know now thanks alot!!
he does have a tech 2 now... soooo he shud be good...
Old Jul 16, 2010 | 12:03 PM
JennaBear's Avatar
Truck Sponsor
Yep, just do the security relearn first.
Old Jul 17, 2010 | 10:05 AM
my engine guy has been attempting the security relearn kast night but its not getting him anywhere...
just to verify
1-attempt to start truck...release key (keep it in the on position, do not turn key off)
2-let sit for ten minutes until light goes out(on my truck theres no light at all)
3-take key out and let it sit for a minute...
4-repeat steps three times?
Old Jul 17, 2010 | 11:04 AM
JennaBear's Avatar
Truck Sponsor
Shoot me an email and we will get you squared away. jenna@blackbearperformance.com
