Engine sounds like crap, and no TC lockup! HELP!
Old Oct 25, 2004 | 05:39 PM
derek_silvy's Avatar
Default Engine sounds like crap, and no TC lockup! HELP!
I noticed last night that it seemed like it was running badly, and at idle it would jerk with intermitant misfires. I am getting this noise too, sounds valvetrain-ish. I've noticed a lil tick very slightly before and let it go, but it is a lil more pronounced and when you rev it up to 3500+ I would say it makes a bad loud sound that I just can't describe. The best way to descrive it is loud tapping I guess. And then, my TC wouldn't lock up on the way home from school. What is happening?
Help please!
I got a torque wrench from work and I am about to go in and check my valvetrain preload, but other than that, I don't know. And no torque converter unlock? I have heard that misfires will make the PCM prevent lockup..... but constantly (about 20 minutes) prevent lockup?!?!?!?!?
The motor doesn't seem like it is as strong as usual, but doesn't feel like it has 100hp or anything.
Help me please!
Old Oct 25, 2004 | 05:57 PM
L-EATER's Avatar
11 Second Truck Club
I can't help you much with the noise without hearing it, but if it sounds "valve trainish" then it probably is. The misfires will definitely prevent the lockup-clear the codes after you fix the problem and the lockup will magically come back.
Old Oct 25, 2004 | 06:08 PM
I am not getting any codes related to missfire....
Old Oct 25, 2004 | 07:47 PM
While reseting my valvetrain preload I decided to pull the plugs and have a look. So far, I've pulled 1 and 3.
One was pretty fricking black, and three had red deposits on it.
Black means detonation ... but I don't know what red means?
Any ideas WTF is going on inside my engine/with my ignition?
Old Oct 25, 2004 | 08:07 PM
Black Blown 02's Avatar
Black means you're running rich. Not detonation. Don't know what red means.
Old Oct 25, 2004 | 08:10 PM
Or detonation....
I'm comparing it to the haynes plug manual.
Old Oct 25, 2004 | 08:11 PM
one03sierra's Avatar
Formerly one92rs
Talking
a slight red tint on the plugs means they are burning correctly last time i checked.
Old Oct 25, 2004 | 08:12 PM
Stroker 1500's Avatar
if there red there burning correctly, the red is just from the additives in the fuel
Old Oct 25, 2004 | 08:25 PM
Or detonation....
If the gap is still within spec and theres no portion of the plug melted away, and no spatters of aluminum anywhere on the plug, then I don't think you need to worry. The detonation example plug in the haynes manual is black, but a black plug doesn't necessarily mean detonation.
Old Oct 25, 2004 | 08:29 PM
Maybe you had a loose plug wire. Is that possible?
