engine running bad
Old Dec 26, 2005 | 01:16 PM
thunder550's Avatar
High on diesel fumes
I have a set of robogrip pliers with the rubber boots that fit over the top. Took a lot of work, but I managed to get them all out. I hadn't loc-tited them in though. If you decide to try, don't take the locking allen-head thingy out of the adjusting nut. Keep them in order, and when you go to put them back in, just torque them back down and they should end up in the exact same position.
Old Dec 29, 2005 | 08:50 PM
white lightning SS's Avatar
Those codes are cam sensor comes. pull it out and make sure you did not dink it w the cam. or if you took it out that the wiring is good and it is seated properly.
stealthperf
34
Feb 14, 2016 11:35 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
ROB 1 TON
Jul 13, 2015 04:43 PM
Mzay
Jul 6, 2015 11:03 PM
