ENGINE PACKAGES
Old Jan 9, 2003 | 04:08 PM
silent1's Avatar
Default ENGINE PACKAGES
i was looking into mti engine packages and wasn't sure what would be the best package to go with(if i were to get a really nice income tax return!) the 422 is way too expensive, the 382 all bore short block is going for $5000. i'm not sure how much for the 382 stroker, should be around the same. i'd like the engine to last quite some time, it would be a daily driver. they both claim 475-525 hp, don't know the torque ratings. which package do you guys think would be best for me, all bore or stroker?
Old Jan 9, 2003 | 04:45 PM
Hybrid Slow's Avatar
Default Re: ENGINE PACKAGES
I'd think the stroker would be cheaper, easier and more reliable? You should be able to use your stock block, with MTI's stroker crank... As opposed to buying a completely new block, or having your current one bored over accordingly.
However, I think the all bore 382 would make more power then the stroker, especially in the low end torque department. Which is really important when you're trying to move a big heavy truck; or if you ever plan to tow anything.
Old Jan 9, 2003 | 05:03 PM
I just noticed that on the all bore 382 package, it includes MTI's Stage 3 ported LS1 heads... Whereas the 382 stroker package only includes their Stage 2 ported LS1 heads?
Also, if you're worried about reliability, MTI also provides a 1 year, 12K mile warranty (provided that the motor is installed by them).
You should also check out what ARE has to offer. They have a sligthly broader range of affordable all bore or stroker applications, from 382 to 388s on up. I think their all bore 382 long-block package is about $8,000 though.
Old Jan 9, 2003 | 05:20 PM
silent1's Avatar
i already have a set of stage III heads and a pretty good valve train, i just want to get a short block. i'll check out ARE and see what they have, thanks.
Corvette454l88
Sep 1, 2016 01:24 AM
shawn96gmc
May 17, 2016 04:15 PM
LoneSStar
Jul 27, 2015 09:27 PM
slowlsx
Jul 13, 2015 04:18 AM
