Engine Hot overheating at idle
Old Dec 31, 2017 | 06:54 PM
FFDP's Avatar
You can buy it either way. Most come in a 50/50 mix or you can mix it yourself to a 50/50 or what I prefer a 60/40 or 65/35 mix. Buying straight coolant is generally cheaper as they charge you for half water in the 50/50 mixtures lol.
Top your coolant off and let it run with the radiator cap off for a little while, let the thermostat open and circulate the coolant and air bubbles out the radiator. Then top it off again and go for a drive, watch the coolant temp, if okay the coolant temp will stay normal. Just don't open the cap when it's hot, don't want to injure yourself and it may bubble some coolant out if there is some air in there.
It was -20 this morning here, I have to pre-mix down to -30 to -35 here.
Old Jan 1, 2018 | 09:36 AM
2002_Z28_Six_Speed's Avatar
No offense to you guys. it was 15 this morning. def dont want to be where you guys are up more north lol
Old Jan 1, 2018 | 10:08 AM
FFDP's Avatar
C'mon, it was only like negative 14ish this morning.
Old Jan 1, 2018 | 12:33 PM
turboal1's Avatar
Default Temp
It was only -6 this morning, the sun finally came out.
still ice and snow covered roads.
Old Jan 6, 2018 | 04:58 PM
Dipstick2's Avatar
Registered User
Thank you everyone for the tips and advice! Turns out it was the water pump. All is good, no damage. Wind chill here is -22F
Old Jan 6, 2018 | 08:39 PM
good deal. that isn't too hard of a fix and not too expensive. i think you can get the ac delco replacement pumps for about 150 and they even come with the gaskets you need.
cadmaro
Dec 31, 2017 01:54 AM
Reckless
Nov 13, 2017 11:41 AM
Chris Dollard
Nov 7, 2017 07:54 PM
LR4Z71
Oct 28, 2017 07:04 PM
