Help Needed with 5.3 cam swap
Old Nov 6, 2017 | 06:23 PM
Chris Dollard's Avatar
Registered User
Default Help Needed with 5.3 cam swap
  1. [QUOTE]Just rebuilt my 5.3 and had to bore out 30 installed replaced the dish pistons with flat top pistons also.
    just recently ran the engine for the first time on a run stand and had issues with the idle I found some great info on how tune the engine to what cam you have and got the engine to idle by itself but its way to high falls on its face when I blip the throttle. I somewhat have a idea what I need to do to prevent that but I would like to have some of yall check the data log out and the tune.
    CAM SPECS
    LIFT: CAM TIMING @50 OPEN CLOSES LOBE CENTER DURATION
    INT@CAM-335 @Valve 569 INT 13 btdc 47abdc 106 int 240
    EXH@CAM-335 @Valve 569 EXH 52 bbdc 20 atdc 106 exh 252
    33 degrees overlap
File Type: hpl
File Type: hpt
Old Nov 7, 2017 | 07:54 PM
RPMSpeed Tech's Avatar
Truck Sponsor
That cam really doesnt belong in a 5.3. youre gonna have to add ALOT of air.
