Engine choice revisited LQ4 vs LQ9
Old Aug 2, 2005 | 02:18 AM
thunder550's Avatar
High on diesel fumes
Default Engine choice revisited LQ4 vs LQ9
I have posted a couple of threads about what I am hoping to get out of my next setup....most of the replies have told me to go with the LQ4 because of the lower compression with boost. But....then I see this thread: https://www.performancetrucks.net/fo...d.php?t=345783
Sounds to me like the LQ9 with a good tune is safe up to at least 10psi...which is probably around where I'll be. So...why wouldn't I go with the LQ9 instead of the LQ4?
Old Aug 2, 2005 | 06:58 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
IMO you arent pushing the envelope so much with lq4 as far as too much CR especially in the hot weather you live in you have to worry about detonation.
Old Aug 2, 2005 | 09:59 AM
thunder550's Avatar
I'll probably replace the small Radix intercooler with the larger optional one as well, if that makes any difference.
This is the part that I focused on:
Originally Posted by PappyDan
I know he will give you as much as your fuel system and injectors can deliver on 91 or 93 Oct, without causing damage to the engine. your final result could be some where around 8 to 11 psi when he is finished.
be sure to post the numbers everybody would like to see.
Old Aug 2, 2005 | 10:21 AM
99Silver6.0's Avatar
You can push much more boost safely through an LQ4. If I were goin boost, it would definitely be an LQ4.
Old Aug 2, 2005 | 01:35 PM
KySilverado's Avatar
LQ4. Probably cheaper and easier to find.
Old Aug 2, 2005 | 01:39 PM
zippy's Avatar
normally i'd be all for the LQ9. with you living in a place that feels like you're sitting on the sun, i'd go LQ4...
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Denali08
Aug 9, 2015 04:34 PM
Alco
Jul 25, 2015 01:47 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
