Electric fans and Pulleys ???
Old Nov 15, 2002 | 06:56 AM
ArticGMC's Avatar
Default Electric fans and Pulleys ???
I hopefully have a set of LS1 electric fans with wiring that someone had on their 02 chevy truck coming in next week. While I was doing the electric fan upgrade I was thinking about doing the ASP pulley upgrade. I was wondering if anyone is/was having any difficulty with the charging problems. I have a 100 watt bazooka and a 360 watt amp pushing my highs. If you do have both, do you have just the crank pulley or both the crank and alternator pulleys? I have the 5.3 engine.
Any help would be appreciated.
Lar
<small>[ November 15, 2002, 08:03 AM: Message edited by: ArticGMC ]</small>
Old Nov 15, 2002 | 08:41 AM
BigTex's Avatar
Default Re: Electric fans and Pulleys ???
You would probably want to have an alternator pulley to keep the voltage up. During the day, you probably wouldn't notice it, but at night with the lights on, it would pull power pretty hard.
Old Nov 15, 2002 | 03:43 PM
graygmc's Avatar
yea what richard said. at night with my lights on the alterntator struggles a little bit. but you could just get ls1edit and raise your idle to about 900rpms.
Old Nov 15, 2002 | 03:47 PM
GREGGO's Avatar
GET THE ALT PULLEY. I have one on mine and I'm running about 1500watts <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> My subs alone run on a 1200watt amp. And nighttime was not my friend with the stock alt pulley. The overdrive alt pulley helped, but I still got to much power. In you case, it should fit the bill.
Greg
Old Nov 15, 2002 | 04:25 PM
ArticGMC's Avatar
Thanks guys for the info. I emailed Tbyrne motorsports and they said that they will hook me up with the right stuff.
Lar
Old Nov 16, 2002 | 10:51 AM
FILE's Avatar
I hear you wont feel a difference with the alt pullie. What is your experience with the alt pullie fast4.8?
Old Nov 16, 2002 | 11:05 AM
parish8's Avatar
single digit dreamer
is there any point in going with pullys if you have an electric fan and dont plan on slowing down the alternator? you would be slowing down the water pump and power stearing, how much is that worth. i am not slaming the pullys but am trying to decide on the best way to get another 1/10 for myself.
Old Nov 16, 2002 | 02:35 PM
eallanboggs's Avatar
You will only notice a difference in charging at idle speed. I usually only have a problem while I'm sitting at a red lite at nite with my headlites on HI BEAM and AC on MAX with my 700 watt stero at FULL BLAST and then decide to push the the cig liter to lite up a dobie when I'm reading CHP magazine with my map lite. Other then that it's no big deal. If it bothers you just get the OVERDRIVE pulley or turn in the throttle stop screw on you TB a couple of turns.
Old Nov 17, 2002 | 12:14 AM
The pulleys are good. All the camaro's and T/A's have electric fans and the run pulleys. They are worth the money!!!
Old Nov 17, 2002 | 12:59 AM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by shark_g:
<strong>I hear you wont feel a difference with the alt pullie. What is your experience with the alt pullie fast4.8?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You don't notice a thing at all with the alt pulley other than more juice when you need it like at night. Horsepower differences is virtually nonexsitant.
Greg
Vortec350ss
Jan 12, 2016 10:36 PM
CD82
Oct 23, 2015 07:32 AM
Lthompson
Oct 2, 2015 12:45 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
