Electric fans on my 2000 GMC Sierra 1500
Old Apr 17, 2015 | 02:27 PM
Dan Neumann's Avatar
Default Electric fans on my 2000 GMC Sierra 1500
Is it worth the upgrade and if so what's the best/easiest route to go to install some? Mine has a 4.8 but I'm planning to build and install a slightly cammed 5.3 in the future. TIA
Old Apr 17, 2015 | 03:53 PM
treylittlefield's Avatar
Ls1 fans and a nelson harness, or make your own
Old Apr 17, 2015 | 04:06 PM
Anyone ever use this?
http://www.ebay.com/itm/Electric-Cooling-Fan-Harness-Switch-Kit-GM-LS1-LS7-LS9-Engines-/151641156629?hash=item234e846c15&vxp=mtr
Old Apr 17, 2015 | 08:15 PM
10 Second Club
I used the PCM of NC kit with a set of hand me down LS1 fans. Nice kit, easy install.
Old Apr 17, 2015 | 08:58 PM
GMCtrk's Avatar
My opinion: NO. Keep the clutch fan. No noticeable difference in power, response, anything and you lose reliability switching to electric fans.
Old Apr 18, 2015 | 08:58 AM
SlowDude's Avatar
Reliability? Ill tell ya whats not reliable is the darn fan clutch! I replaced at least 5 of them the first ten yrs I owned my truck. Swapped to "BeCool" fans and a good harness ran thru the computer and have not had an issue the last 3 yrs.. Not to mention you now have two fans and the chances of both going out are slim to non! Although the gas savings is minimal, there still a slight gain in mileage and no drain on the motor which has to be worth something.. I say go with the fans. The way it should have came from the factory to begin with!
Old Apr 18, 2015 | 10:48 AM
01silvy's Avatar
I also did the efan swap. I just bought a 34" core radiator like from the newer trucks equipped with efans and then bought the e fans from ebay that go with the newer models. All in all i had about $400 tied up in it and it totally chenges the way your engine compartment looks, it cleans it up a lot. This isnt one of those modes where you will pick up 20 hp and 3 mpg but it is one one of those mods that adds to the overall package. Its a good supporting mod to do along with other things. I also used the blackbear efan harness
Old Apr 18, 2015 | 08:07 PM
DaddyDrake's Avatar
Registered User
Is there any pcm tuning needed? Thinking bout doing this also
Old Apr 19, 2015 | 03:00 AM
wirelessf's Avatar
If you are lucky you might be able to find an 05-06 truck in the junkyard. I was able to get the fans and the factory fan relay for <$100 which is wayyyy cheaper and factory than those flexalite fans. Assuming that you have the 34" radiator (get it with the fans) and a blackbear tune (efan tune only is $55) in that might cost more.
Old Apr 20, 2015 | 09:22 PM
2Slow_00's Avatar
I called Just Chevy Trucks today and ordered some fans and relays for $360 smthn and ordered the cheapest 34" core radiator off ebay for like $86... my clutch fan has lasted 15 years but my radiator has a crack from a deer I hit and my tranny is pulled right now so ima upgrade while im down
