Electric Fans?
Old May 1, 2004 | 04:57 PM
4.8redchev's Avatar
Default Electric Fans?
looking to do a mod....thought about electic fans are they worth it and how much would it cost to do them any hp gains or mpg gain?
Old May 1, 2004 | 04:59 PM
MacADaYear's Avatar
I love mine...
I think the going rate is ~100 for fans and 50 for a controler.
Whole thing should cost ya less than 200 ...scrounged mine up for 125
Old May 1, 2004 | 05:01 PM
4.8redchev's Avatar
haha does the motor run cooler or anything good about them and do you have to run them all the time or somethin?
Old May 1, 2004 | 05:03 PM
MacADaYear's Avatar
It wont run cooler... actually in a way its running hotter because there isnt the constant stock fan running. But your gonna want a 160deg Tstat to keep the temps down
Old May 1, 2004 | 05:09 PM
4.8redchev's Avatar
so what basically happens when you do get them is there a hp gain or waht and also i have a hpp3 if i get the 160deg thermo can i ture my hpp3 off that wit the fans? so 200 bucks basically for what i mean what does the eletic fans do?
Old May 1, 2004 | 05:24 PM
MacADaYear's Avatar
The efans frees up power since your engine doesnt have to turn the stock fan and clutch anymore. I think ive seen someone say from 6-8hp. If you have the hpp3 and the 160 stat then yea tune the hpp3 for the 160, but your efans are goin to run off a temp probe that you will put into you radiator.
What your lookn for is to run around 175.. so when you hit about 180-185 you can have you fans turn on untill the temp goes back down. When im driving around my fans dont usually come on, but I have a modded tstat instead of a 160 tstat, so its a little different.
BTW- the 160 tstat does not run at 160 so its not just you lol
Old May 1, 2004 | 05:36 PM
4.8redchev's Avatar
haha ok good where do i buy these fans from and are they are to put in wire etc? so whenever my engine will go ver 180 i just hit the switch and let it cool down and turn them off? but when i turn them off shouldn't it go back up? just want to ask a few questions im either thinking a hd hood or e fans thanks chris..
Old May 1, 2004 | 05:45 PM
TRW427SS's Avatar
Removing the stock fan is worth about 4-5rwhp on the dyno!
Old May 1, 2004 | 05:54 PM
MacADaYear's Avatar
The wiring wasnt hard .. just follow the directions on the VSC controler.
As far as the on/off , the controler is gonna handle that for you and for the most part you wont have to worry about it. The only switch I have is a manual on which is optional. The usual operation is automatic.
Old May 1, 2004 | 06:17 PM
speedy02's Avatar
Just get LS1 fans from a junk yard.They work good.
