Electric Fans?
so what basically happens when you do get them is there a hp gain or waht and also i have a hpp3 if i get the 160deg thermo can i ture my hpp3 off that wit the fans? so 200 bucks basically for what i mean what does the eletic fans do?
The efans frees up power since your engine doesnt have to turn the stock fan and clutch anymore. I think ive seen someone say from 6-8hp. If you have the hpp3 and the 160 stat then yea tune the hpp3 for the 160, but your efans are goin to run off a temp probe that you will put into you radiator.
What your lookn for is to run around 175.. so when you hit about 180-185 you can have you fans turn on untill the temp goes back down. When im driving around my fans dont usually come on, but I have a modded tstat instead of a 160 tstat, so its a little different.
BTW- the 160 tstat does not run at 160 so its not just you lol
haha ok good where do i buy these fans from and are they are to put in wire etc? so whenever my engine will go ver 180 i just hit the switch and let it cool down and turn them off? but when i turn them off shouldn't it go back up? just want to ask a few questions im either thinking a hd hood or e fans thanks chris..
The wiring wasnt hard .. just follow the directions on the VSC controler.
As far as the on/off , the controler is gonna handle that for you and for the most part you wont have to worry about it. The only switch I have is a manual on which is optional. The usual operation is automatic.
