EGR removal
Old Jan 28, 2005 | 08:08 AM
GREGGO's Avatar
Default EGR removal
Now that Edit is working, I am going to turn off the EGR. First, will I show a "not ready" for emmisions? and second, what all needs to be toggled to make sure it and all codes are off.
Old Jan 28, 2005 | 08:56 AM
BigKID's Avatar
Not sure about you first question since we dont have emission checks here but the codes you need to toggle to TypeX = turned off are P0400,401,402,404,405,
Old Jan 28, 2005 | 01:10 PM
Whistlin00's Avatar
14 Second Truck Club
Will turning off the EGR help out on performance?
Old Jan 28, 2005 | 01:43 PM
XLR8NSS's Avatar
Adkoonerstrator
If you turn off the code and set it to type X it will not cause any problems with emissions.
I thought I already told you that. Your new name is BlackBeaSSt.
Old Jan 28, 2005 | 03:45 PM
greentahoe's Avatar
Id like to know this as well. I remember reading that it will worsen part throttle gas milage and I THINK I remember reading that it also adversely affected part throttle performance. I know it would keep things quite a bit cleaner!
Old Jan 28, 2005 | 03:57 PM
BigTex's Avatar
On my 99 truck with EGR turned off, it would ping and stumble more under load at low rpms. I turned it back on. I'm sure a really good tune that altered VE, timing, fueling, etc under those conditions would fix the issue.
Old Jan 28, 2005 | 04:53 PM
greentahoe's Avatar
Looks like mine will have to stay put. Do you think that perhaps the PCM intentionally runs lean due to the expectation of the recirculation of unburned fuel maybe and when the EGR is removed it runs a little lean? Its probably substantially more complicated than that, but does that sound plausable?
Old Jan 28, 2005 | 10:19 PM
CashDudeHomie's Avatar
What if I just leave the egr crap off but don't tune it, will the truck start? I don't mind the SES light, since it's on anyway.
Old Jan 29, 2005 | 02:31 PM
XLR8NSS's Avatar
Adkoonerstrator
Yes, the truck will start fine.
Like BigTex mentioned above disconnecting the EGR without some tuning might cause some pinging.
Old Jan 30, 2005 | 11:19 AM
GREGGO's Avatar
How about if I got a PCM from and 01 or 02 without egr. I just want that ugly POS out, plus, it just kills my T/B.
