egr question ?
I just cut the egr off in my intake manifold and I also cleaned it out with carb cleaner. Now it idols ruf and whenever i touch the gas it goes up to 2000 rpms and takes a few seconds to go back down to idoling. Is this because of the carb cleaner or cutting the egr short? Also, can I turn off the egr sensor with nelson's tune and just plug the holes?
Originally Posted by 01 Thunder
yes you can have Allen turn the EGR off. you would need to block the EGR tube on your header, and plug the hole in the side of the intake with a freeze plug.
That's a lot of work.
I just made a gasket from a big sheet, cut it to size, and put it between the EGR valve and the tube from the exhaust manifold to the intake.
I did mine the other way just because it cleaned up the engine a bit.
and removed it completely
Sure it'd make it cleaner but where is that extra harness going to go? you have to look real close to find it
plus it's turned off so it doesnt do anything anyways.
