egr plug
Old Jul 18, 2011 | 07:52 PM
Default egr plug
Will an egr block off plate from a ls1 ws6 fit my 5.3? His mounts on the top of the intake.
LS1 EGR Billet Aluminum EGR Intake Block Off Plate NEW | eBay
Old Jul 18, 2011 | 07:59 PM
neilownz's Avatar
Just get the gm one or use a freeze plug. It's much cheaper.
http://cgi.ebay.com/ebaymotors/LS1-5...-/120743537423
Or use something like that.
Old Jul 18, 2011 | 08:08 PM
2doorfury's Avatar
is egr delete fairly easy?? i have a 03' 5.3....is there a delete kit i can buy??
1Bear's Avatar
The part number for the plug from GM should be 12558346.
Old Jul 18, 2011 | 08:44 PM
Not sure if theres a kit but you need two block off plates. one for the intake and one for the exhaust. ebay sells both. Also you need to turn off the codes releated to the egr or else the check engine light will come on.
Old Jul 18, 2011 | 08:46 PM
Yeah I already have that one but the end is so thin I can't get a good seal with a temp sensor under boost so I want to try something different
Old Jul 18, 2011 | 08:48 PM
LS1 5.3 Vortec EGR Block Off Intake Manifold Plug Kit | eBay
I tried that before I used an expandable freeze plug and it was a hair too small. I was worried that it would leak under boost.
Old Jul 18, 2011 | 09:11 PM
1Bear's Avatar
Understandable
Old Jul 18, 2011 | 11:39 PM
SlickSierra's Avatar
i used a 1 3/8-1 1/2 rubber freeze plug, 1 1/4-1 3/8 plug is too small. Making a little aluminum plate for the exhaust is easy but my tuner gave me one.
Old Jul 19, 2011 | 01:14 AM
I want a temp sensor in this spot, so it needs to be tapped
