Edelbrock Headers
Old Sep 23, 2003 | 12:43 AM
02chevyracing's Avatar
14 Second Truck Club
Default Edelbrock Headers
Is anyone running eldebrook headers? if so what do you think of them? yeah or nah?
Old Sep 23, 2003 | 12:46 AM
FILE's Avatar
Default Re: edlebrook headers
I think edlebrock only makes shorties. You will get better results if you go long tubes.
Old Sep 23, 2003 | 01:06 AM
Phatchevy's Avatar
i have them and i like them a lot. they make two types of headers. one is a shorty header and the other is what THEY call a long tube header system. it's more of a mid length. it's called the edlebrock TES system. it comes with the headers and the y-pipe. they are also stainless steal but i would recommend getting them coated anyways. before i got them i ran a 16.00 at the track w/ airaid intake and programmer and 2-chamber flowmaster. after the headers i ran a 15.3e.t. there is no rubbing and i haven't had any problems.
Old Sep 23, 2003 | 01:15 AM
FILE's Avatar
.7 off your 1/4 mile time with just header and Y pipe.....
Old Sep 23, 2003 | 05:16 AM
jchorner99's Avatar
i have the edelbrock shorties. they were an oops..
Old Sep 23, 2003 | 11:12 AM
Avalanche2002's Avatar
I had the TES system on my 94 Sonoma, the y-pipe made the difference. It was a lot larger diameter than stock. I did have a problem with one of the heat shields, one of the spot welds popped and I had to remove the header, remove the heat shield, and weld up the holes in the tubes where the spot welds were. After that, no more problems. It made a significant difference in power. Shorties, in my opinion, aren't worth the small gain over the full-size truck stock manifolds.
Old Sep 23, 2003 | 03:20 PM
FLASH's Avatar
shark_g where did you get your headers? are they long tubes? did they help? and what do they come with
Old Sep 23, 2003 | 05:31 PM
ThunderZ28's Avatar
12 Second Club
i got edelbrock shorty's with a true dual,and 2 flows on mine. notice a little diferance. i bet they help out better than nothing at all. but if i could do it over again i would go with long tube headers.chek out Arizona Speed and Marine.
Old Sep 23, 2003 | 05:40 PM
FILE's Avatar
I got my header from Tbyrne. They are long tube and they did help a lot throught the rpm range. They came with gaskets only
Old Oct 2, 2003 | 01:12 PM
are these hard to install? does it invole any welding?
