Ebay Headers...Need help with banging around after install
Hey guys. I just got the ebay headers installed with a Dynomax "Super Turbo" Muffler installed. The truck runs great and is actually pretty quiet for what it is. The problem is that when I am turning to the left the driver side header touches the driveshaft (where the four bolts connect the driveshaft with the Yolk). It creates a nasty banging or metallic machine gun noise depending on speed.
It isnt touching much but it has put some scratches onto the header collector and worn away the part of the driveshaft down to nice shiny new metal. How do I go about getting the driveshaft off of the collector? This only happens at slow speed by the way. Do I dent the collector a little bit to get it off? Do I file the very corner of the bolts on the DS Yolk?
HELP.
Mike
HELP.
Mike
Before you go hammering on the header, you could try loosening up the motor mounts and shifting the engine over a little, this is how I got clearance between my StainlessWorks and the right side frame, and probably why andrew383 after he did his engine swap
black03rcsb
Sep 1, 2015 10:17 AM
therock
Jul 25, 2015 09:23 AM
sauldgold
Jul 23, 2015 02:15 PM
