Eaton Posi help ...
Old Jun 20, 2004 | 09:29 PM
Flyer's Avatar
Default Eaton Posi help ...
How do I pull the axle's out of the carrier. It's dark and I can't hardly see anything, me not knowing what to look for doesn't make it any easier. Anyone have any suggestions?
Do I need to take the carrier retainers off before I can pull the axles out?
Old Jun 21, 2004 | 01:59 AM
sleepersilverado's Avatar
no first you need to un bolt the calipers and take the rotors off. there is a rod going through the middle of the carrier that has a single little bolt in it and two spidet gears on it take that out. ( that is if you have an open diff) if it is a g80 i believe there is something similar but it is just a little slide thing with no spider gears on it. after you do that the push the axles into the axle housing more. then you will be able to remove the c-clips from the end of the axles. now you can pull the axles out a bit (but dont be jerking them so you dont accidently mess up the axle seals. now you can take the carrier bearing caps off and pull the carrier.
Old Jun 21, 2004 | 03:25 AM
Hit Man X's Avatar
I dunno it iw was mentioned or now but... make sureto pull the corss pin other wise you can't push the axles in enoughto to pull the "C" clips out...
Old Jun 21, 2004 | 03:57 AM
you dont know because you cant read or type do to too much
Old Jun 21, 2004 | 01:06 PM
Flyer's Avatar
It's the G80 ... so .. is this thing something I need to pry out with a screw driver or what?
Old Jun 21, 2004 | 01:13 PM
Hit Man X's Avatar
Sorry. I spent last night painting my house and kickin' a few back with the boys that were helpin' me.
Old Jun 21, 2004 | 04:48 PM
no it should slide out fairly easy after you remove the bolt but i think on those it does not come compleetly out. the one i did had to be pried loos because the rear blew up.
Old Jun 21, 2004 | 08:50 PM
Flyer's Avatar
OK ... maybe this can help. Which side do I pull something out of to push the axles in to take the c clip off to get the axles out? Any other info you might think would be useful would be appreciated too.
Old Jun 21, 2004 | 11:49 PM
Flyer's Avatar
TTT for me
Old Jun 22, 2004 | 08:30 AM
bigguy75inches's Avatar
hey flyer, stop showin off your rear end you perv!
