Easiest way to pull engine and trans at once???
Old May 1, 2018 | 05:58 PM
dry_kill's Avatar
Default Easiest way to pull engine and trans at once???
Well I found a deal on a low mileage full 5.3 motor and trans complete, heard it run and triple checked everything. Even ran a carfax on it and the carfax confirmed the sellers story. Anyway the only thing bad thing is it's still in the truck. What would be easiest and fastest way to pull motor and trans out?
There front driver side is smashed so I don't have to be too careful but condensor and radiator didn't sustain any damage, ac still works.
And I do own a engine hoist just in case people were wondering
Old May 1, 2018 | 06:35 PM
FFDP's Avatar
Straight out the front.
Remove everything, rad, condenser, core support etc etc.
Old May 1, 2018 | 06:36 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Unbolt front sheet metal from cab including core support from frame,
Sling engine,
Pull Transmission crossmember,
Remove bolts from engine to frame mounts,
Jack up the engine with the hoist and Pull hard!!!
Old May 1, 2018 | 06:41 PM
dry_kill's Avatar
Do I have to pull bumper to pull the core support out?
Old May 1, 2018 | 06:56 PM
1FastBrick's Avatar
Nope. There is literally 2 bolts down through the core support. will have to yank grill if its still there. but thats easy...
I believe there a 16MM. Hold the top head and spin the nut off on the bottom.
Old May 1, 2018 | 07:07 PM
dry_kill's Avatar
Ok cool got it. Ima try to have it out as fast as possible. Tired of the damn engine situation been going through
Old May 1, 2018 | 07:20 PM
1FastBrick's Avatar
Oh that's right.... You getting a refund from the other guy or what?
Old May 1, 2018 | 07:22 PM
dry_kill's Avatar
I'm still waiting for him to get another engine for me. If I get a refund they charge a 30% restocking fee so I say I'd rather just take another engine and save it for my 02 Silverado maybe later down the line
Old May 1, 2018 | 07:31 PM
1FastBrick's Avatar
"If" he gets you another one...
Legally they can't charge you a restocking fee for a defective product. Under the warranty they can provide you with another or refund your money after a set amount of time.
Either way if he was on the up and up he would just give you a full refund and let you go away happy.
Hopefully he does make it right.
Old May 1, 2018 | 08:18 PM
dry_kill's Avatar
Oh forgot to ask, I know about the 2 bolts for the core support but aren't there some bolted to the fenders as well?
405hpta
May 23, 2007 10:27 PM
thunder550
29
Nov 14, 2006 11:51 PM
AJII
Sep 10, 2006 08:14 PM
BradS
Sep 18, 2005 06:05 PM
4.8redchev
Dec 19, 2003 02:20 PM
