Easiest way to change oil pickup tube O-ring?
Old Nov 13, 2006 | 09:20 PM
  #21
my black ss's Avatar
Originally Posted by thunder550
Grrr.....what is a feeler gauge and where do I get one?
its like a small pack of metal shims usually starting at about .5 one thowsants i believe i payed six bucks for mine at any parts place you can run a ported ls6 pump from texas speed its ported for optimum flow and has a heavier spring for more pressure
Old Nov 13, 2006 | 09:28 PM
  #22
thunder550's Avatar
High on diesel fumes
Cool I'll call them tomorrow. Thanks.
Old Nov 13, 2006 | 09:42 PM
  #23
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Get a low mileage stock pump, port the housing yourself and throw a little shim in the cylinder where the spring is at. Its not worth spending the money for what you get. Many people have done it and oyu will get the same result.
Old Nov 13, 2006 | 09:51 PM
  #24
thunder550's Avatar
What is involved in porting the housing?
Old Nov 13, 2006 | 09:56 PM
  #25
1slow01Z71's Avatar
Using a dremel to knock down the casting flash on the inlet(where the pikup tube goes). That is the only place that I noticed that was "ported" on my Thunder Racing ported LS6 pump. I sold it because I figured I could do it myself and have the same result and sell the TR pump for some cash since it is TRported pump.
Old Nov 13, 2006 | 10:04 PM
  #26
thunder550's Avatar
Hmmm.....I think I'm just gonna do the O-ring for now, then if I still have issues I'll just tear into it again.
Old Nov 13, 2006 | 10:56 PM
  #27
i ported one of my pumps and it worked fine but the reason i told him to go with texas speeds pump is because its cheap and reliable ...guys as easy as it is to do people with little to no experiance should not be porting on the heart off there motor its not the first place to sharpen yor porting skills and if you have the money$130.00 its worth it when you consider the cost of a motor ...and dont take it wrong im not nocking anyones ability here im just trying to help
Old Nov 14, 2006 | 12:36 AM
  #28
desTRUCKtive's Avatar
yes just replace the o ring, I need you to be the pig on the bed. I am having the same problem. If it does not work then I will help you replace the pump. SOme one had a write up around here anyone know of one.
Old Nov 14, 2006 | 10:38 AM
  #29
FarmerBeau's Avatar
Sexy Party Mod
You are supposed to use a .002 feeler guage all the way around and set the clearance between your oil pump and crank. I tried for 30 minutes to get it right and gave up. Everytime you tighen the bolts(even if you do it evenly ) it moves it the slightest bit and throws your clearances off.
Like i said, i gave up and didnt mess with it. Just slapped it back on and bolted her up. No issues and put 7k miles on it since. It was running fine when i broke a headbolt off in the block and bought a new block. I didnt even try when reassembling the new motor. We will see how it acts.
Old Nov 14, 2006 | 11:51 PM
  #30
thunder550's Avatar
Decided to go in from the bottom, made my truck a 2wd so it was easy!
Then I found metal shavings . Different thread about that here.
Oobray
Jun 13, 2022 03:38 AM
Bluchevypick
Aug 18, 2015 09:11 AM
Ls3silverado
Jul 31, 2015 04:22 PM
Ferocity02
Jul 17, 2015 07:05 PM
Mzay
Jul 6, 2015 11:03 PM
