e-fans almost in...
Old Dec 22, 2006 | 08:01 PM
Kingpimp's Avatar
Default e-fans almost in...
The problem I'm having is the plastic edge of the e-fan is resting on my radiator. Won't this dent and eventually break a hole in the radiator? Do I trim some plastic off, or just make brackets to keep i off the radiator?
Old Dec 22, 2006 | 08:06 PM
14 Second Truck Club
Which Fans?
Old Dec 22, 2006 | 08:49 PM
blake2kz71's Avatar
if your talking about the f-body fans, i used some thin rubber pieces that would go on something like door jam moldings like weather stripping.
Old Dec 22, 2006 | 08:57 PM
Kingpimp's Avatar
Thanks guys, but I just cut off the plastic ****. I put one side of the fans into the original shroud bracket, then made two metal strips that hang and mount to the original holes at the top.
I'll try to get some pics if anyone is interested.
And Yes, I was talking about the LS1 Fans.
Old Dec 22, 2006 | 09:06 PM
blake2kz71's Avatar
i did about the same thing when mounting the fans. just used the factory fan shroud holes. and i used another strip of metal to sit on the radiator where the fan shroud set and drilled through the e-fan shroud.
Old Dec 22, 2006 | 10:15 PM
Kingpimp's Avatar
Yep, that's what I did too.
Old Dec 22, 2006 | 10:18 PM
04BlackGmc's Avatar
10 Second Club
hmm didnt have this problem. i rested the bottom under the fan between the frame area and Rad. and the top peice mounted with some metal tabs doesnt really touch anywhere.
Old Dec 22, 2006 | 10:45 PM
LS1TRUCKGUY's Avatar
i used the whole stock shroud, and trimmed off the excess. i idint use any metal tabs or anything. the fans come out just as if you were taking the shroud off.
thunder550
Oct 8, 2015 04:53 PM
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
2000_Silverado_SS
Sep 18, 2004 09:02 AM
