e-fans almost in...
The problem I'm having is the plastic edge of the e-fan is resting on my radiator. Won't this dent and eventually break a hole in the radiator? Do I trim some plastic off, or just make brackets to keep i off the radiator?
Thanks guys, but I just cut off the plastic ****. I put one side of the fans into the original shroud bracket, then made two metal strips that hang and mount to the original holes at the top.
I'll try to get some pics if anyone is interested.
And Yes, I was talking about the LS1 Fans.
i did about the same thing when mounting the fans. just used the factory fan shroud holes. and i used another strip of metal to sit on the radiator where the fan shroud set and drilled through the e-fan shroud.
lycominghunter
26
Sep 25, 2015 07:50 AM
