E-fans are in!
Old Jun 4, 2008 | 04:21 PM
00ChevyScott's Avatar
Wearin' da big hat
Default E-fans are in!
and I can tell a tiny difference in throttle response and a bit better regular driving power.
They're also pretty quiet suprizingly, but they werent when I accidently had one of the fans reversed
If you can pick up a set, I'd deffinately suggest it simply because of how much room it free's up in your engine bay.
Will post pics if anyone wants em.
Old Jun 4, 2008 | 04:23 PM
Mangled03gmc's Avatar
Baltimore Whore
Sweet thats good to hear that there is a diff compared to the stock fan. I just picked a set up of eaby last night. What kit are you using to wire them in nelsons???
John
Old Jun 4, 2008 | 04:27 PM
Wearin' da big hat
well all of my money is tied up the cam right now, so I just ran up to O'reillys and got 30 ft of red, and 30 ft of black wire, some quick disconnects, a fuse holder (30 amp), zip ties, and a toggle switch.
It works great, but is only temporary until I can afford a harness. But this way would be a great setup for the track since I can leave the fans on while the motor is off waiting in the staging lanes to help with heat soak.
Old Jun 4, 2008 | 04:40 PM
cmb570's Avatar
what efan kit did you go with ?
Old Jun 4, 2008 | 04:56 PM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
Old Jun 4, 2008 | 05:46 PM
Wearin' da big hat
fans out of a 98 LS1 fbody, for $70 bucks local
Right now it is being held up by black zip ties until after the cam install monday, but it is still clean, just not as sturdy as it will be once I make up some brackets.
Old Jun 4, 2008 | 06:04 PM
post teh bracket pics...did you get any measurements by chance?
i wanna make some brackets for mine, but don't feel like takin the clutch fan off putting the e-fans on, then putting the clutch fan back on to see how small of a sheet i need of metal.
Old Jun 4, 2008 | 06:09 PM
Wearin' da big hat
This is not my bracket design, taken from this website
http://bertok.us/agreif/fans/fanstech.htm
Old Jun 4, 2008 | 06:35 PM
lady3bglover's Avatar
If you'd like I can post a couple pics of my fan install..... I also have the trans cooler as well. lmk
Lisa
Old Jun 5, 2008 | 05:16 PM
jleonard711's Avatar
I just did this upgrade, too. While I didn't notice too much of a performance gain, it definitely still has its positives. First, and the biggest thing for me here in AZ (where it gets to be 110-115 in the summer), is that the e-fans keep your A/C running a LOT cooler when you're sitting still. The old clutch fan just didn't move enough air when the truck was sitting at idle, so it would blow out warm air unless I'm going at least 15mph+. Now it blows ice cold all the time!
Also, there is SO much more room to work with in the engine bay now, it's incredible! I swear I could almost get in there and stand in between the motor and the radiator now. That damn fan & shroud took up so much room! And long-gone is the annoying "whhhooooosh" sound of the clutch fan.
And I'm also getting better mileage after the install - I went from 14.8 up to 15.5!
I personally went with the 05+ OEM GM fans, simply because I didn't want to mess around with fabbing a mounting bracket for the LS1 fans. Also, I've heard that the OEM truck fans move a lot more air than the LS1 fans, and I need all the cooling power I can get here in the desert. I got the OEM e-fans from eBay for $250 + a Nelson wiring harness for $100 = $350 for the whole job, and it was worth every penny.
EDIT: BTW, unless you have a stock 6.0L LQ4 (w/34" radiator), then you would need to upgrade your radiator to the new 34" if you want to use the OEM 05+ e-fans.
thunder550
Oct 8, 2015 04:53 PM
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
2000_Silverado_SS
Sep 18, 2004 09:02 AM
