E-fan problems
Old Sep 21, 2005 | 08:30 PM
04Denali's Avatar
Default E-fan problems
I am having problems with my e-fans, I hope you guys will be able to understand what I am going to try and explains because I don't.
Yesterday my truck started getting a little warmer than normal. it was only 75* outside. when I got home and popped the hood my fans were not on. I turned the ac on and the passenger side fan kicked on like normal but the drivers side was not working. Normally the computer will start the drivers side on low and the ac will start the passenger's side on high. so I switched some of the relays around to see if one was bad and now the computer will start them both on low and when I turn the ac on the drivers side will turn on high and the passengers side will turn off. Doesn't make sense to me. The relays all look the same to me and now I'm not sure which ones went where originally. I had someone else install the fans so I don't know how he did it.
any insite would be greatly appreciated
Mark
Old Sep 21, 2005 | 08:37 PM
Jeff Alexander's Avatar
on the side of the relay their should be a diagram as long as their both the same diagram you can interchange them
Old Sep 21, 2005 | 09:13 PM
04Denali's Avatar
I think that I have determand that the middle relay is not working. Where can you buy these? and what would make it go bad @ less than 2 months.
Does anyone know how much thay are? not that it matters, have to get it fixed, just courious
Mark
Old Sep 21, 2005 | 09:25 PM
budhayes3's Avatar
PT's Slowest Truck
You can get those relays at most parts stores or Radio Shack. The relay that went bad might just be defective, or the contacts wore out...a number of things may have caused it to fail.
Old Sep 21, 2005 | 09:37 PM
04Denali's Avatar
Thanks
It was working fine for about 2 months and than right before it went bad I had a spark plug wire pop off and I was miss fireing really bad for about 10 min. before I could pull over and check it out, than after that the fan quit working, gotta be a coinsidence.
Mark
Old Sep 22, 2005 | 12:43 PM
04Denali's Avatar
Up date on fans, went and got another relay and put it in and it still won't work and now the fans won't start even with the AC on. So now I have no fans!!! I put the old one back in and still nothing, nada, zilch, and before someone asked if the are wired correctly I have know Idea, I didn't install them myself. All I know is they worked fine for 2 months and 3000 miles. any body have an Idea, thought or anything.
Mark
I can't drive my truck until I or WE figure this out, so please help me
Mark
Old Sep 22, 2005 | 03:19 PM
jmproductions's Avatar
Mark
Mark
Have you checked all your fuses? Might be a bad fan drawing too much current and blowing relays and fuses. What do you think guys?
Old Sep 22, 2005 | 04:05 PM
you need to check if your getting power,and ground,to the fans. fuses, fuseable links
check if your getting power to the relay
Old Sep 22, 2005 | 04:26 PM
budhayes3's Avatar
PT's Slowest Truck
Also make sure that all of the connections are good, and that there isn't any blown or unseated fuses.
Old Sep 22, 2005 | 06:40 PM
1badgmc's Avatar
I had trouble with a bad connection with my ground. Once that was fixed i haven't had any more probs. Good Luck!
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
