E-Fan HELP! Why is my PIN 42 12V+??
Old Mar 12, 2007 | 04:34 PM
2002C5COUPE's Avatar
Question E-Fan HELP! Why is my PIN 42 12V+??
I just installed my fans, and the one that is supposed to be controlled by the PCM will not come on.
I've triple checked that it's in the correct location and installed correctly, and i've swapped fan plugs around to make sure the motor is good, and it is.
Shouldn't the blue wire (from pin 42 to relay) go to ground to start the fan? Mine is hot even w/ the truck off
Old Mar 12, 2007 | 04:57 PM
budhayes3's Avatar
PT's Slowest Truck
Yessir, pin 42 should ground when the engine reaches the temp that your fans are set at...I can't remember if it's the blue or red pcm connector though. There shouldn't be any voltage there
Old Mar 12, 2007 | 05:24 PM
That's what i thought. It's a blue wire, the other is green and it's the a/c pwr trigger.
Maybe my PCM programming is wrong. Is it possible that he accidently set it up to go + at the desired temp., instead of go -??
Old Mar 12, 2007 | 05:32 PM
truckmann's Avatar
I don't think there is an option to change the output of the pin. At least there isn't with HP tuners. You can only change when it is grounded or not by setting the temp for the fans in the program.
Old Mar 12, 2007 | 05:38 PM
oh ok.
well what in the world would cause it to be + then??
i'm on the pcm closest to the engine, and on pin 42, i've double checked it 20 times now. i know i'm in the right spot, but not sure what is going on.
Old Mar 12, 2007 | 05:48 PM
truckmann's Avatar
When you are testing the voltage for pin 42 of the blue connector I would unplug all the relays. I am suspecting you have another wire that is meant to be to a ground on a positve source and that would be where the + voltage is coming from....
Please don't ask why I am coming to this conclusion. It will make me feel stupid.
Old Mar 12, 2007 | 06:13 PM
Ok i got it! I'm an electrical idiot! Everything was working fine, i just tested it wrong, and didn't wait long enough for it to come on.
thanks for the help though!
Old Mar 12, 2007 | 06:17 PM
truckmann's Avatar
Good to hear. The occasional moment of stupidity happens to the best of us...
Old Mar 12, 2007 | 06:50 PM
bluecajun5.3's Avatar
11 Second Truck Club
make sure you have the pin pushed in all the way. they are tricky.
Old Mar 12, 2007 | 08:19 PM
Wheatley's Avatar
Truck Sponsor
Good to hear it is working now man.
Porscharu914
14
Jan 20, 2016 10:45 AM
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
trxmxzx
Sep 29, 2015 07:42 AM
kalikid06
Sep 20, 2015 07:46 PM
