E-Fan Harness Install
Old Mar 15, 2007 | 04:11 PM
Possessed666's Avatar
Default E-Fan Harness Install
For you guys that have E-fans and are using the nelson harness or something similar, where did you mount your relays and with what?
I have everything in and in working order, just can't come up with a clean way to mount them in my head.
Any help is appreciated and if you have a picture that would be even better.
Thanks.
Old Mar 15, 2007 | 04:24 PM
budhayes3's Avatar
PT's Slowest Truck
I mounted mine right on the PCM cover with a screw...you could also use velcro or strong 2 sided tape. Sorry I don't have a pic though...
Old Mar 15, 2007 | 04:35 PM
2002C5COUPE's Avatar
I would've mounted mine on the PCM cover but my harness seems a little backwards. The ring terminals would not have reached if i would've mounted it.
So the relays are kinda zip tied into place until i come up with a solution.
Old Mar 15, 2007 | 05:07 PM
Tootall's Avatar
I mounted mine right to the fan housing. Search my name about making your own harness, I made one that was under $30 bucks, wire relays and all. I did not use the gm weather pack plugs. There are a couple members here that make/sell these.
Old Mar 15, 2007 | 05:41 PM
truckmann's Avatar
Mine are mounted on the inner fender below the fues/relay box.
Old Mar 15, 2007 | 05:46 PM
NegraRCSB2X4auto's Avatar
to sc tubing running down to the inter cooler.
Old Mar 15, 2007 | 08:55 PM
PNBLWZD's Avatar
I noticed that the tabs on the relays were on the wrong side for mounting to the PCM cover also (backwards from what Nelson's instructions show). I removed the relay tabs completely, and instead used one of the 3 holes found on the side of the plastic relay socket assy. Pull one relay out, carefully shoot a *short* screw through that hole into the PCM cover (so the plastic doesn't strip), and replace the relay. I pulled the one closest to the firewall because it allowed the relay bank to attatch while it's still in a natural hanging position, yet still be secured.
Velcro wouldn't stick to the plastic PCM housing, FWIW.
Old Mar 15, 2007 | 10:34 PM
RoosterMcCandles's Avatar
I mounted mine on the fuse box with a few screws...
Old Mar 15, 2007 | 11:07 PM
SnakeOiler's Avatar
I put mine under the fuse box cover
http://i2.photobucket.com/albums/y28...s/Efans007.jpg
Old Mar 16, 2007 | 10:44 AM
Thanks for the responses guys, very helpful.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
mr03silverado
Jul 17, 2015 02:15 PM
