Dyno'ed the mule yesterday
Old Sep 19, 2004 | 01:54 PM
Quikenuf's Avatar
Default Dyno'ed the mule yesterday
2002 GMC SCSB
5.3 stock internals.
E-fans, custom 4in. intake
thorley headers, custom Ypipe. no cats.
single 3in exaust w/ cut out open
only tuning was rev limiter at 6000, cheapo gas
temp 94 degrees and around 80% humidity.
Hp-263.7
trq-270.2.
Torque seems a little low, but the hp is about what i figured. what can i do to get that torque number up? I still have stock pulleys, and the only reason for not tuning it was i just got the truck back from the dealer for warranty work and its so damn hot, i dont see much use. I know i could have gotten more out of it, but i just wanted a baseline b4 cam springs and thunder racing tune.
Old Sep 19, 2004 | 03:44 PM
02Reaper's Avatar
Can you post the dyno graph?
Old Sep 19, 2004 | 04:13 PM
tooquick2beslo's Avatar
Also I have a question about your sig. You ran a 13.7 with a stock 5.3 N/A ?
Old Sep 19, 2004 | 06:31 PM
F8L Z71's Avatar
That sounds about right. Grats
That's 20rwhp or so higher than my truck stock with just a K&N so it sounds good to me.
As for the ET and MPH, no way that was on the stock setup unless that truck only weighs 3700lbs or less.
Old Sep 19, 2004 | 09:13 PM
Quikenuf's Avatar
The dyno setup was no tuning except for rev limiter and speed limiter moved up. i work very hard with tuning timing and fuel at the track that i had set back to stock when i took the truck in for warranty work. none of the tuning was there b/c i just got my truck back friday. also dyno time was 94 degree heat and about 80% humidity which is going to kill power also. I ran my best time In January, at 37 degrees and around 25-30% humidity. i do alot of ET reducers at the track that the dyno numbers are not going to reflect. in ex: slicks weight reductionand a short belt that was not run on dyno, couple traction mods too. Yes its very possible to run my times on a stock internals 5.3. Have you ever heard or Lotsofn? while he had his truck, he was running 13.20s at 100.
Old Sep 19, 2004 | 09:39 PM
goshawk23's Avatar
Truck addict
yea lotsofun had that truck running mighty quick for stock internals. i have been witness to it run at thundershootout.
Old Sep 19, 2004 | 10:24 PM
Dark Halo's Avatar
maybe there is some hope for my 4.8 after all
Old Sep 19, 2004 | 10:58 PM
F8L Z71's Avatar
Notice I said stock. Not stock internals. and I did mention weight reduction. Weight reduction is the same as adding HP
Old Sep 19, 2004 | 11:17 PM
SnakeOiler's Avatar
Hp-263.7
trq-270.2.
Would the lack of backpressure cause your low tq number?
Old Sep 20, 2004 | 08:30 AM
You ran a 13.7 with weight reduction ? What did you take off ?
The bed? I am really curious not doubting.
