Dyno Estimates??
Old Jan 10, 2005 | 07:07 PM
  #31
F8L Z71's Avatar
I have no clue what my HP is.
Last time we tuned the truck it got a lot faster but we didn't have a dyno near my tuner. The last place I used wont let me back on with the stock tires. They grew and distorted so bad the workers got skeerd.
My old setup didn't feel nearly as fast as it is now and that was at 436rwhp with the GT35 turbo.
Now I have the GT67 .81 A/R. stock 6.0L heads and 8.6:1 CR, FMIC and a much better tune. Still no dyno tuning though. Just street tunes with a wideband.
On pump gas with a tiny bit of meth I was running avg. 106-107mph at the track. Then I went back after I lost some compression due to water damage. I added some C16 race gas and the temps were about 20+deg cooler and I never once went slower than 108.9mph. I turned the dial 1psi and got the 110mph but my trans was slipping so bad people in the stands thought I blew it up. LOL
If you try and use a calculator that would say I am making 549rwhp (110mph) at 14.5psi with a 5250lb raceweight. I doubt it is that high as the HP curve feels very linear and solid. Not peaky at all. It's most likely lower but nice and flat.
As for lag. I got tons. If I don't boost off the line then I could be fully through a large intersection before I get into any decent amount of boost. Once I hit about 6psi though boost comes on so damn fast that the tires will start to break loose at about 30mph.
I raced an LT1 SS once at night and the guy just took off on me and instantly had 3 cars. I hit boost and started sliding to the side spinning the tires at about 35mph and I was gaining on him a tiny bit, once I hooked it was over and I flew passed him. Not that this was cool by any means but it shows you what lag can do to a race if you are not properly set up. Had I brake stalled it and built up boost he would have seen nothing but tailights.
I'll show you a vid of no boost off the line and one with boost.
Only got about 2psi on this launch
http://fatalfoo.com/Movies/F8L%20Z71...%20vs%20GN.wmv
8psi launch then a 6psi launch.
http://my.starstream.net/f8lpony/Jus...0-%20Small.WMV
Old Jan 10, 2005 | 08:28 PM
  #32
8ALTNG's Avatar
That is funny that you say you have tons. A guy out here with a 347 and a gt70 has barely any lag. The second vid only plays the 1st 12seconds but i have seen it before. Thanks for the info it helps alot knowing that you have the kit on your truck.
Old Jan 10, 2005 | 08:37 PM
  #33
F8L Z71's Avatar
My GT35 had very little lag at all. Once I did the GT67 I had a bunch so I downsized the A/R but added the FMIC and it was the same.
The guys with the 6.0L get very little lag with the GT67 so I'm guessing the extra cubes push that much more CFM so lag is lessened. Please let me know how yours turns out. I'm very curious how it will work on the 4.8L.
Old Jan 10, 2005 | 09:07 PM
  #34
8ALTNG's Avatar
[QUOTE=F8L Z71 I'm very curious how it will work on the 4.8L. [/QUOTE]
Will do
Old Jan 10, 2005 | 09:29 PM
  #35
Mangled03gmc's Avatar
Baltimore Whore
[QUOTE=LTNKLR01]
Originally Posted by F8L Z71 I'm very curious how it will work on the 4.8L. :)[/QUOTE
Will do
hey maybe i missed it but what turbo set up are you going to be using.Good luck with what ever it is.
Old Jan 10, 2005 | 09:34 PM
  #36
8ALTNG's Avatar
i am using the sts gt67 kit
Old Jan 10, 2005 | 09:39 PM
  #37
Baltimore Whore
have you decided on going with a ic or meth/alky or both.just a lil curious because i have been kicking things around for awhile about FI and have the money to spend now.just don't know what i want.Hope that things a beast when your done
Old Jan 10, 2005 | 09:55 PM
  #38
8ALTNG's Avatar
I am going with a front mount intercooler. I dont think that i will need the alky or meth. With my tuner working his magic i should have no problem.
Old Jan 11, 2005 | 01:21 PM
  #39
8ALTNG's Avatar
F8L- do u think that i am going to need alkey/meth injection????? just wondering
Old Jan 11, 2005 | 01:24 PM
  #40
Noyzee's Avatar
8 second mod
not with a good tune, good gas, and a good intercooler. i made 13psi with no problems with good gas, im sure you will be fine also, unless gas is an issue.
