Dual exhaust on 03 6.0L?
Old Jan 17, 2004 | 03:01 PM
GMC2500HD's Avatar
Default Dual exhaust on 03 6.0L?
I have a 03 2500hd with a 6.0 in it. Mild mods, Predator, UPD, Free mods, my next step is exhaust. I took it to an exhaust shop in town and he recommended going with the magnoflow muffler. I was looking to cut the exhaust off before the muffler and going true dual's with the magnaflow mufflers. He was telling me to use a single magnaflow that cross's the exhaust path then run duals out the back. He said that makes a crossover and has real good flow. He said a true dual set up can confuse the computer and make one bank run either lean or rich? I am looking for as much hp as possible ( I know there is much to be found in the cat back of the exhaust) but I figure if I doing it I might as well do it right. He also said that the muffler is fairly quite. If I hammer the throttle I do want to hear the exhaust though. How do these mufflers sound?
Old Jan 17, 2004 | 03:08 PM
Yelo's Avatar
The Magnaflow is a very good choice....alot of people here seem to like them very much
I run a true dual setup and have had no problems with one bank running rich or lean (less than 1% difference on my ltrims) so if you want to go that way you can probably do so with no problems...the crossover setup is a better way to go though
Old Jan 17, 2004 | 03:39 PM
Hit Man X's Avatar
Well if you go with two mufflers, that's twice the cost. And you'd need an extra H or X crossover for the exhuast pressure to equalize. Magnaflow makes a muffler that has that stuff built in already. It's just cost effective.
Old Jan 17, 2004 | 04:26 PM
1BADHD's Avatar
I have a dual in/out Flowmaster 50 series. Sounds great and didnt loose any low end!
Old Jan 17, 2004 | 08:01 PM
Sorry to here that some muffler shop don't know what they are talking about ,the ECU won't read anything past the B1S2,B2S2, all you're going to get is a little difference in backpressure easy fix with an X(best) or an H to equalize the pressure
Old Jan 17, 2004 | 09:05 PM
prnracing's Avatar
we did duals with a X piped and we gained low end torque with the setup
later
perry
Raggedz71
Jul 29, 2016 10:20 AM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
Zack R
Aug 3, 2015 06:02 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
