Dropping my Suburban Need help ?
Old Feb 3, 2005 | 11:53 PM
Default Dropping my Suburban Need help ?
I am putting Eibach Springs on the rear and It Is a pro kit. I was wondering feedback on height to lower torsion bar. Also having them Install brembo rotors and Axxis pads tomorrow. I got a steering wheel out of an escalade and putting that in also. Looking forward to tomorrow. B
Old Feb 3, 2005 | 11:59 PM
McGaughys drop spindles do a great job without touching the torsion bars.I'm running their 2"/3" drop with stock shocks and it still rides pretty good.You do need to run 18" or larger wheels.
Old Feb 4, 2005 | 12:02 AM
How much and where did you get those ?
Old Feb 4, 2005 | 12:04 AM
Mr. Sandog's Avatar
Did you get the 2" (1.8") drop springs, or the 3" (2.8") drop springs?
It's best if you do the springs first, then turn the torsion bar bolts after you take measurements and decide your stance. It also depends on if you want your truck level or with a rake.
Old Feb 4, 2005 | 12:06 AM
Mr. Sandog's Avatar
McGaughys sells direct - McGaughys - if you want to go that way. It is a 2" drop. I think they will make you buy their whole kit however, including springs. Personally, I liked the ride of the Eibachs better.
I got the pro kit told It Is 1.5 drop ? Is this correct I hope ?
Old Feb 4, 2005 | 12:07 AM
Mr. Sandog's Avatar
What's the part number?
Old Feb 4, 2005 | 12:08 AM
3887.520 pro kit
Old Feb 4, 2005 | 12:17 AM
Mr. Sandog's Avatar
That's the 3" (2.8") drop spring. Those are stiff springs, but they will make your Sub handle like a Vette. I started off with those springs, but they were about a half inch too high for me, so I swapped in the McGaughys springs. I hate them. I lost all the sweet handling I had with the Eibachs, they're soft and lean like hell in the corners. And the ride isn't that much better. Now I'm getting a set of custom springs made close to the Eibach spring rate (337 lbs) but 1/2" lower, like the McGaughys. I think the McGaughys are sprung like stock, which is somewhere around 225 lbs.
If you have the 3" drop springs you will either need to get the McGaughys spindles or torsion keys to drop the front. What stance are you after?
Old Feb 4, 2005 | 12:19 AM
Mr. Sandog's Avatar
BTW, this really belongs in the Suspension section.
