Drilling TB blade for startup and idle
Old Jun 25, 2014 | 07:25 AM
  #21
trxmxzx's Avatar
13 Second Truck Club
I get the same as last video but mine dies out very quickly maybe three times it jumps rpms and dies- I have a 90mm edelbrock- wonder if this is my issue it's annoying
Old Jul 8, 2014 | 09:58 PM
  #22
NuckenFuts's Avatar
OP any update on this? did you get a new tune to fix the problem?
Mine is really jacked up now and will not start when engine is hot. FML
Old Jul 9, 2014 | 10:51 AM
  #23
nickleahy23's Avatar
Ive messed with it a little bit. I drilled out my hole a few sizes bigger and slightly adjusted the throttle stop. Its not perfect yet, but its getting there. Cold i dont get a perfect start, but warm it starts up no problem and no issue with high idle. I think im going to go one size bigger on the drill bit and reduce the throttle stop and see where that gets me. The IAC should be able to make up for some of it to smooth out the idle, ill hook up the laptop and watch the steps and data.
Old Jul 9, 2014 | 12:43 PM
  #24
TXsilverado's Avatar
quit drilling if you do not have a scanner to see what your IAC is doing. quit screwing throttle position if you dont have a scanner to watch the TPS voltage. that's my suggestion.
Old Jul 9, 2014 | 04:01 PM
  #25
Originally Posted by MPFD
I meant the top of its range during slow cruise or idle, not high RPM. Mine counts from 0-about 100 and 80-100 isn't much room for making adjustments when it trying to compensate for the throttle blade slamming shut.
i'm missing you here. the IAC can range from 0-160 (off memmory). so 60-80 is right in the middle zone of of 0 IAC (min) and 160 count (max). you mentioned seeing zero IAC at idle on your truck...i would never expect to see zero at idle. that means you have no control over your idle (and way too much air is getting past the throttle blade on an EFI setup). max closed can be just as problematic as max open.
Old Jul 9, 2014 | 04:21 PM
  #26
I have a v2 and EFIlive to watch the IAC. im at 0% TPS at idle and it doesnt fluctuate. Idle is perfect when driving and after warm start up. I need to confirm what IAC is at to see if I have room to adjust a little more so that cold start up works without giving it some throttle.
What way does it work? If im low on IAC steps, I have room to give it more air, and if im high on IAC steps, I am getting too much air?
Old Jul 10, 2014 | 06:05 PM
  #27
do a search for the russ k idle airflow config. it will help with those cold start issues.
Old Jul 10, 2014 | 06:12 PM
  #28
or send me your e-mail address and i will send the config to you.
basically you run the config from a cold start in park a few times. then run the config from a cold start in gear a few times. turn off the electric fans and let it idle without touching it until it gets to 260* engine temp. it will spit out some numbers that you paste into your tune. it helps a ton with cold start.
Old Jul 10, 2014 | 06:15 PM
  #29
Cold engine key on, start scanning (disable e-fans), then start engine & let idle till 250* temp without touching the throttle. Then copy the #1 idle desired airflow histogram (average) and paste into the RAF table of the editor. Make sure that the same units (imp. or metric) are used in both the scanner & editor.
Repeat in gear if A4 trans.
i had the best results by running the config a few times.
File Type: cfg
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
twake_410
Sep 25, 2015 10:09 PM
lxcoupe
Sep 25, 2015 12:36 PM
